Old 03-16-2021, 01:26 PM   #1
scottmitchellrose
convert 69 c20 drums to disc front?
I have a 69 C 20 I want to convert to disc? Any idea what I need/ where to go (new or junkyards)? 8 lug obviously... Thanks for any advice,
Scott
scottmitchellrose is offline   Reply With Quote
Old 03-16-2021, 02:23 PM   #2
Steeveedee
Who Changed This?
Steeveedee's Avatar
Re: convert 69 c20 drums to disc front?
Easiest for all the fit is to snag one from an existing vehicle. Everything will be there for the taking, hopefully. There will be little to no guessing about where things go, especially if you take some photos first. I bought a kit but had problems with it- damaged and missing parts The other aspect of it is that when (if) you ever go to the parts store, you will know the year of the truck. My truck has the original crossmember, so the attach point for the brake hoses is at the rear, and the disc brake lines extend to the front. It's a minor thing, but still annoying. If you don't have a way to support the engine, swapping crossmembers might be a problem. A used crossmember would also be a LOT cheaper. Take everything from the booster on down, if you go that way.
~Steven
Simi Valley, CA
Old 03-16-2021, 02:30 PM   #3
scottmitchellrose
Thanks! Any advice on what year (s) would work best for an 8 lug?
Old 03-16-2021, 02:41 PM   #4
Myself
Can't you just swap the squarebody stuff over like a 1/2 ton?
Myself is offline   Reply With Quote
Old 03-16-2021, 03:16 PM   #5
BigBird05
Get a donor truck, 73 to 84 and take the whole front end and brake parts off of it and maybe even the rear axle.
BigBird05 is offline   Reply With Quote
Old 03-16-2021, 03:20 PM   #6
Sheepdip
Sheepdip's Avatar
73-87 A arms out will bolt right on.
Sheepdip is offline   Reply With Quote
Old 03-16-2021, 03:25 PM   #7
BigBird05
If you go to disc, your drum brakes rims may not fit. I know that is the case for 15" drum brake rims.
Old 03-16-2021, 03:35 PM   #8
Big Kev-O
Big Kev-O's Avatar
If you find a donor car, make sure to get all of the steering components too. The center link on the 67-70, 71-72 & 73up are all different. They use different tie rods. Keep in mind any donor you find is probably going to need new ball joints & tie rods anyways. You will also need to swap the brake master cylinder and proportioning/metering valve as well.
There is a way to use 71-72 C20 disc spindles with your 68 center steering link but you will need to use 68 outer tie rods on the inside position with special tie rod adapters and 71-72 outer tie rods to connect the spindle.
There is a pretty detailed thread on the using 71-72 C20 spindles thread here:
http://67-72chevytrucks.com/vboard/s...d.php?t=804757
Made in America by Americans
Last edited by Big Kev-O; 03-17-2021 at 01:30 PM. Reason: I think all 3/4 ton C20s 67-87 all have steel bushing control arm cross shafts.
Big Kev-O is offline   Reply With Quote
Old 03-16-2021, 03:37 PM   #9
BigBird05
Big Kev-O, I don't think he can use parts. off of a donor car. LOL
Old 03-16-2021, 04:11 PM   #10
LockDoc
The Older Generation
LockDoc's Avatar
Scott
This is a pretty comprehensive conversion thread.
LockDoc
Leon
Old 03-16-2021, 04:36 PM   #11
scottmitchellrose
Thanks to all! I may know of a 73-87 donor here in Durham NC.
Old 03-16-2021, 08:07 PM   #12
May70
May70's Avatar
Big Kev beat me to my old thread. I would suggest reading it completely, most importantly post #10.
A lot of mis-information in some threads on the forums.
70 C20 Build link : Project Montezuma
http://67-72chevytrucks.com/vboard/s...d.php?t=794479
How to repair that rusted out 67-72 c10-c30! Please subscribe!
https://www.youtube.com/c/MaycoCustomRestorations
May70 is offline   Reply With Quote
Old 03-16-2021, 11:10 PM   #13
hounddogs!
Restoring it $200 at a time...
hounddogs!'s Avatar
One more thread to add to the pile..
This shows how I supported the motor from the top and pulled the loaded crossmember out from under it.
http://67-72chevytrucks.com/vboard/s...d.php?t=587600
'71 parts went back in.
Charter member of the 'Put the dimmer switch back on the damn floor where it belongs' Society
'68 5.3L-4 speed LWB C20; grandpa bought it for the farm in '71. Now LS 5.3, rather than 327.
DD '09 Pilot
Weekender '65 Skylark 300-4V-4 speed
Wife's '07 Lexus ES350; 117 actuator motors and I can't see the engine.
Son's '04 F250 SuperCab 6.0
hounddogs! is offline   Reply With Quote
Old 03-18-2021, 08:19 AM   #14
Andy4639
Old member
Andy4639's Avatar
Talking Re: convert 69 c20 drums to disc front?
My thread's on swapping in a full 86 disc front end in my C-20 Ramp truck.
I'm looking for a disc brake rear end now for it.
https://67-72chevytrucks.com/vboard/...=725462&page=2
https://67-72chevytrucks.com/vboard/...d.php?t=809465
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
brake conversion
