Old 03-19-2021, 02:11 PM   #1
Furno68C20
Throttle linkage 2 Barrel Carb
Truck - 67 c20 283ci in the i6 position.
The throttle linkage angle seem to me a little off. I just recently swapped the v8 in place of a i6.
Will the i6 linkage work on a 2 bbl v8 set up?
The See pictures below. sorry for the picture angle..
Thank you,
Grant
67 C10 Fleetside SOLD
67 C10 SWB Fleetside
67 C20 Fleetside
68 C10 Fleetside
68 C20 Fleetside SOLD
72 k20
Pay Pal: Grant.Furneaux@gmail.com
Furno68C20 is offline   Reply With Quote
Old 03-19-2021, 02:38 PM   #2
Willys_MB
Willys_MB's Avatar
Re: Throttle linkage 2 Barrel Carb
That looks similar to my 68 327ci setup. I just switched to the throttle cable setup from a 71-72. If you need a spare I can post it in the parts board.
1968 GMC C2500 Long Bed Fleetside
Willys_MB is offline   Reply With Quote
Old 03-19-2021, 06:32 PM   #3
Furno68C20
Can you or anyone post a pic of your set up?
Old 03-20-2021, 12:17 AM   #4
lil hoodlum
lil hoodlum's Avatar
Can you switch the throttle linkage to the inside of the bracket in the rear?
Currently you have it on the outside position in the rear.
lil hoodlum is offline   Reply With Quote
Old 03-20-2021, 05:37 AM   #5
notsolo
notsolo's Avatar
You can also make an adapter plate, use the 2 pivot holes to attach, then add new holes in your adapter for throttle linkage. You can level out the rod better with a longer piece. Same process if you add an auto trans and need cable hook up like photo.
notsolo is offline   Reply With Quote
Old 03-20-2021, 08:15 AM   #6
Grumpy old man
Grumpy old man's Avatar
Get rid of the "death linkage " and switch to cable .
