Points to HEI problems
I have currently took out my points and added an HEI distributor. Ever since I've done that the truck will burn up my starter. I've gone through three starters. Do I have to disable the ignition pulse amplifier for my AGI to work? Has anybody else had this kind of problem? Thank you in advance.
![]() ![]() ![]() Join Date: Jan 2018
Re: Points to HEI problems
Do you still have 3 wires going to your starter? You should only have 2 with an HEI. Power and trigger wire
Also, would you like me to move this thread to the electrical forum section?
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 350, Saginaw 4 speed "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
![]() Join Date: Jan 2011
First how did you wire it and did you bypass the resister wire from the old setup. Next going through starters with an ignition change is a timing issue in most cases.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
I have removed the resister wire and ran a switch power to the distributor.
That is the problem it does not turn over at all. I believe I have multiple issues. I got frustrated and put it away a couple months ago. Just pulled it out and started tinkering again and now I'm having problems with the horn relay. So many issues I don't know where to start.
![]() Join Date: Sep 2006
It is safe to hook the HEI to the pink wire from your ignition switch.
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 |
| Bookmarks |
| Tags |
| hei, pain in the ass, points, starters |
