Old 03-21-2021, 03:25 PM   #1
Keith Seymore
Keith Seymore's Avatar
Anybody know how to remove these heater hose fittings?
I'm mostly interested in the white quick connect, which no longer has a nipple on it and which has my quick connect removal tool stuck behind it -
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 03-21-2021, 03:26 PM   #2
Keith Seymore
Re: Anybody know how to remove these heater hose fittings?
It's an 04 2500HD with a Duramax; I could get the fitting to move forward but it didn't come off.
K
1979-1986
1986 - 2019
Old 03-21-2021, 04:25 PM   #3
Getter-Done
Getter-Done's Avatar
My neighbors blew out when he was heading fishing one day.
I seen the trail on the highway.
He came back a few minutes later
Luckily he was close to home.
Here is a video that I hope will help
https://www.youtube.com/watch?v=1-SPALplsO8
The early bird gets the worm,
85 Chevy K-20
Old 03-21-2021, 05:29 PM   #4
Keith Seymore
Originally Posted by Getter-Done View Post
May neighbors blew out when he was heading fishing one day.
Thank you; basically I'm doing what he recommended for the Silverado. I guess I'll keep trying, only harder.
I am glad it happened a couple miles from home and not on a trip to Atlanta or somewhere.
K
1979-1986
1986 - 2019
Old 03-22-2021, 11:10 AM   #5
hatzie
Moderator
hatzie's Avatar
It might be worth making a fork to pry against the fitting.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 03-22-2021, 12:26 PM   #6
Keith Seymore
I was hoping you might have some input.
I found an old Cub Lowboy shift fork in my junk metal pile; I'm going to try hooking the slide hammer to that and give it a whirl.
Thanks -
K
1979-1986
1986 - 2019
Old 03-22-2021, 03:02 PM   #7
Boog
laying low
Boog's Avatar
Keith you probably have already thought about it but slide hammering on that fitting may pop a leak on the heater core. I worked and worked to get mine to release using the tool that eventually worked.
What you might try is a dremel tool or similar to split that coupler lengthwise then peel it off the tube.
Boog
Old 03-22-2021, 06:32 PM   #8
hatzie
Moderator
hatzie's Avatar
These come in handy at the strangest times.
You don't run as high a risk of cutting through the metal tube inside as you do with power tools.
Old 03-22-2021, 07:09 PM   #9
Keith Seymore
Thanks guys; I got it.
I was able to get my quick connect tool unstuck and I was moving the fitting around in order to "reset" and start over, and it came right off.
I think the stuck tool was preventing the fitting from slipping off.
K
1979-1986
1986 - 2019
Old 03-22-2021, 10:00 PM   #10
Getter-Done
85 Chevy K-20
Old 03-23-2021, 10:21 PM   #11
BigBird05
I have replaced those replacement fittings twice on my Yukon. They all seam to leak just a little. So I bite the bullet and bought GM ones.
BigBird05 is offline   Reply With Quote
Old 03-27-2021, 06:58 AM   #12
S10Fan
Old Heap Driver
Attachment 2090905
That's what I used, came off in seconds. I cut it just enough to use a screwdriver in the cut slot to break the plastic.
_____________________________
Bryan
'99 Silverado 1500, 4.3, 5-speed, reg cab, short bed
'50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser.
'40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver.
S10Fan is offline   Reply With Quote
