Old 03-22-2021, 10:35 PM   #1
1badtransam
1badtransam's Avatar
1970 GMC Floor Mounted Gas Pedal replacement
I'm finishing up a sniper EFI conversion with a lokar throttle cable hook up. My pickup is a manual transmission with a original floor mounted gas pedal.
Do I have to replace this with a aftermarket floor mounted pedal or is it easier to install the firewall mounted one?
LOKAR has both floor mount as well as firewall. Anyone ever done this?
I hope this makes sense.
Thanks!
Fred
1965 LeMans * 1968 CJ5
1969 Firebird * 1970 GMC Truck
1975 Trans Am * 1952 Pickup
1979 Trans Am * 1982 Trans Am
1976 CJ7 * 2000 Trams Am
1badtransam is offline   Reply With Quote
Old 03-23-2021, 12:00 AM   #2
Steeveedee
Ram-A-Lam-A-Ding-Dong
Steeveedee's Avatar
Re: 1970 GMC Floor Mounted Gas Pedal replacement
If your original pedal isn't all cracked and still pivots on the ball studs, I'd say go ahead and run that.
~Steven
Simi Valley, CA
Old 03-23-2021, 12:28 AM   #3
1badtransam
The original pedal is in good shape so I guess I could still use it. I’d have to figure out a way to attach the throttle cable to it.
The top of pedal itself presses against a rod that goes thru the firewall which attached to the original throttle cable.
Not sure how I could get the old pedal to push or pull against the new throttle cable.
Old 03-23-2021, 02:40 AM   #4
pjmoreland
pjmoreland's Avatar
If you want to convert to a 71-72 cable style gas pedal, then check this out.
http://67-72chevytrucks.com/vboard/s...hlight=Adapter
pjmoreland is online now   Reply With Quote
Old 03-23-2021, 09:07 AM   #5
old51sedan
old51sedan's Avatar
Thanks!
Fred
I'm also looking at installing a newer pedal assembly in my 69 truck. I was in the bone yard last week and it is full of early seventies cars and trucks with gas pedals using a cable. I believe I'm going back this week and remove one from maybe a Cadillac, Buick, and/or Oldsmobile. They are all about the same, may need a little tweaking but should work with out to much of a hassle. I want the flexibility of the cable and like the fact that I don't have to cut the carpet below the pedal. Some of these cars have the pedals with aluminum trim, if so I may also get the brake pedal to match. The brake pedals are also bigger than the ones in our trucks, they may have to be altered to fit, but I believe they look better. Just something to think about.
old51sedan is offline   Reply With Quote
Old 03-23-2021, 11:47 AM   #6
1badtransam
Thanks Steve, the original pedal is in great shape. Definitely in the mix if the firewall mount goes south.
Old 03-23-2021, 11:49 AM   #7
1badtransam
Very helpful, thanks PJ.
Old 03-23-2021, 11:55 AM   #8
1badtransam
I love the idea of pulling a pedal out of something else and making it fit for your install. I installed trans am exhaust tips on the end of my trucks tail pipes. No one knows they match my trans am but me.
If I install the LOKAR pedal attached to the firewall, I will have hole in the caret.. which will get replaced anyways but maybe some nice mats will cover it in the mean time.
I also called LOAKR and they did say that the NEW gas pedal will sit closer to the firewall than the original floor mount pedal... I guess I will just have to get used to that.
Old 03-23-2021, 12:06 PM   #9
1badtransam
Here are a couple of photos before I start tearing everything apart. Don't judge the mess under the dash...
Old 03-23-2021, 12:26 PM   #10
Willys_MB
Willys_MB's Avatar
I did this upgrade fairly recently. It took a little while to get used to the firewall mounted pedal instead of floor mounted, but I never looked back. It felt a lot more responsive and tactile. It's worth noting that my linkage was pretty worn out, which is why I did this upgrade. I would totally recommend it. There's a board member who makes the adapter plates and sells them so it just bolts right in. I'd say it took me... 2 hours? Including driving to the parts store. Make sure you get the right throttle cable/bracket/ball stud to mount it all.
1968 GMC C2500 Long Bed Fleetside
Willys_MB is offline   Reply With Quote
Old 03-23-2021, 12:46 PM   #11
1badtransam
Thanks for the feedback on the new pedal position.. sometimes I get tied up on something when it changes... but I'm sure I will love the new responsiveness compared to what was there.
PJ posted the link to the adapter. Hopefully I ordered the right parts as well!
Thanks again.
Old 04-03-2021, 10:54 AM   #12
1badtransam
Question Re: 1970 GMC Floor Mounted Gas Pedal replacement
Here is an update : I drilled out the two of the three original threaded holes like the loose instructions said too. Also drilled out the hole for the throttle cable just above the pedal location. Bolted everything up and connected the throttle body to the cable and pedal and so far so good. Here are some photos
Thanks for everyone’s input.
Old 12-14-2024, 10:29 AM   #13
jcurtis72
What is the trick to getting link to work? Tells me I don’t have permission
jcurtis72 is offline   Reply With Quote
Old 12-14-2024, 11:12 AM   #14
pjmoreland
pjmoreland's Avatar
That thread seems to be gone or disabled. Here's a related thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=745643
Old 12-15-2024, 12:09 AM   #15
MikeB
MikeB's Avatar
I'm looking to do the same as 1BadTransAm using the Lokar pedal assembly, cable and cable bracket, along with their TH350 detent cable. But, man, is it an expensive solution at $508 total!
Mike
1969 Custom/10 LWB -- owned for 37 years. 350/TH350, 3.08 posi, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. Hedman stainless headers. Old Air installation in progress.
1982 Custom Deluxe 10 SWB -- converted from 250-six to roller cam 350 w/ Vortec heads -- sold
1981 C10 Silverado LWB, 305, TH350C -- sold, but wish I still had it!
1969 C10 (not the current one) which I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 26 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
Old 12-15-2024, 08:23 AM   #16
That thread is in a admin area and only those with admin rights can access it. I am assuming something was an issue and they sent a copy to the admin area. This is the thread in the common area,
although it is several years old you would have to check with member '70 402 to see if he is still doing those adapters.
NOTE: it appears he may still be doing them on ebay
https://www.ebay.com/itm/29620574751..._redirect=true
Old 12-15-2024, 12:50 PM   #17
MikeB
MikeB's Avatar
Yes, that appears to be the listing for '70_402's parts. His last activity here was late August 2024, so he's still around. I just sent him a private message to confirm the part's availability. I assume the other listings are from ChiCom copycats.
Mike
firewall mount, floor mount, gas pedal conversion, lokar
