Old 03-24-2021, 11:27 AM   #1
Chuck A
Chuck A's Avatar
Which way would you go?
I've installed the wheel/tire combination I want for my truck. These are 15"X8" 6 lug X 5.5 truck Rally wheels with 255/70/R15 BF Goodrich Radial TAs.
Now I need to make a decision on trim rings. Looking for the opinions on what I should do and why.
Should I leave it alone and not run a trim ring?
If I did go with trim rings, which size? 2" or 3"?
I'm already wishing I had not put the white letters out and will probably change that soon. Please keep the ribbing to a minimum for the Martha Stewart ruler.
Thanks!
Chuck
Chuck A is offline   Reply With Quote
Old 03-24-2021, 11:33 AM   #2
1971Stepside
Almost Satisfied
1971Stepside's Avatar
Re: Which way would you go?
Need a pic of the whole truck
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021.
"I can't complain, but sometimes I still do. Life's been good to me so far."
1971Stepside is offline   Reply With Quote
Old 03-24-2021, 11:45 AM   #3
Chuck A
Chuck A's Avatar
Sorry I guess whole truck pictures would help. Here you go!
One is with the old wheel/tire combo which I hated and one with the new wheel/tire combo, but before I added the correct center caps.
Note: I replaced the springs & shocks over the winter which is what raised the ride height. I expect it will settle down a few inches.
Thanks!
Old 03-24-2021, 12:01 PM   #4
1971Stepside
Almost Satisfied
Beautiful truck. Since you have the chrome trim I would say go with the beauty rings, but I like the rally both ways.
Old 03-24-2021, 12:11 PM   #5
jamesi20
jamesi20's Avatar
personally I like the 3" on the trucks but bottom line is it is your truck so do it the way you like it. You get to look at it every day so make it what you like best
jamesi20 is offline   Reply With Quote
Old 03-24-2021, 12:24 PM   #6
dagnabbitt
dagnabbitt's Avatar
I grew up in the 80s and 90s so I like having white letters out, and I run without trim rings because I can't bear to scratch up the rim, even if you can't see it and it does no actual harm.
But: for a nice, subtle stock looking truck like yours I would do 2" with black tire. Just my opinion.
DAVE
Edmonton, Alberta
1959 Apache
1967 K20
1968 C20
1970 C10
1972 GMC 2500
1981 C10
Old 03-24-2021, 12:57 PM   #7
72-CH
72-CH's Avatar
I went with 2.5 inch rounded from Coker tire. They are about as close to original I could find.
72-CH is offline   Reply With Quote
Old 03-24-2021, 01:02 PM   #8
EagleChief
EagleChief's Avatar
I like the trim rings... maybe the 2"?
1971 C10 - Hugger Orange/White
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=780197
LS Swap Thread: https://67-72chevytrucks.com/vboard/...d.php?t=811460
EagleChief is offline   Reply With Quote
Old 03-24-2021, 02:04 PM   #9
Chuck A
Chuck A's Avatar
Wow, great compromise solution. Definitely going to check out this option! thank you 72-CH!
Old 03-24-2021, 02:44 PM   #10
cj847
cj847's Avatar
Here are my 3" trim rings on what must be 7" rims. Hence they look too deep. They may look fine on your rims if they are 8".
cj847 is offline   Reply With Quote
Old 03-24-2021, 03:08 PM   #11
Chuck A
Chuck A's Avatar
Wow, those completely cover up the square holes in the wheels! My rims are 8" inches. Took a long time to find them in 6 lug. Bought 2 other sets in my quest before finding the exact look I wanted. I'm leaning towards the 2 1/2" trim rings from Coker tire. Thanks for the photo! Are those square edge or rounded edge trim rings?
Old 03-24-2021, 04:34 PM   #12
RenoKeene
Florida Edition
RenoKeene's Avatar
3" rings on 15x8 Rallys with white letters out. I personally love this look, like back in the day.
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod
67 C-20 Slant Back Wrecker "Mad Max"
67 C-10 Ratrod "Step-N-Wolf"
71 Serro Scotty Sportsman camper "Scotty"
97 LT1 Z28 "The Hornet"
Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684
Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394
RenoKeene is offline   Reply With Quote
Old 03-24-2021, 04:52 PM   #13
72-CH
72-CH's Avatar
Here are the Coker tire 2.5 inch rounded trim rings I mentioned earlier.
Old 03-24-2021, 04:54 PM   #14
CG
BlahBlahBlah
Personal opinion here, Rallies need trim rings or they look like someone stole your trim rings.
CG is online now   Reply With Quote
Old 03-24-2021, 05:09 PM   #15
Chuck A
Chuck A's Avatar
That’s the way I’m going to go. Really like the way it looks!
Coker is sold out, so I’ll need to find them somewhere else.
Old 03-24-2021, 05:10 PM   #16
Chuck A
Chuck A's Avatar
Love the knock offs!
Old 03-24-2021, 05:24 PM   #17
72-CH
72-CH's Avatar
Just FYI, I ordered two others sets from other vendors claiming to be rounded trim rings, only to return them because they were not.
When I found the Coker version they were on back order so I had to wait for them to arrive and I am glad I did.
Old 03-24-2021, 05:48 PM   #18
weasel29gm
SLOW BUT SURE,BUT CLOSER
3" on mine same tire. Timeless look
69 C-10, OWNED 38YRS... 350 over 30, 350 Turbo, 3:73 Posi P/S, P/B Black with red and black int. ''LOVE THESE OLD ''TRUCKS.......
weasel29gm is offline   Reply With Quote
Old 03-24-2021, 05:56 PM   #19
Brocoli Wad
Here’s mine. I think they’re 3” rings. I need to replace them and repaint the wheels, but I’m keeping mine in this configuration.
Brocoli Wad is offline   Reply With Quote
Old 03-24-2021, 07:05 PM   #20
cj847
cj847's Avatar
Brokoli Wad,
Where did you get those rims? They look like car rims which I thought only came in 5 on 4.75 and mostly 14"? I prefer those over the 73 up truck rims.
Old 03-24-2021, 07:13 PM   #21
BigBird05
My vote is the old school look. 3" trim rings with the letters out. But I am planning on running Craiger SS on mine.
BigBird05 is offline   Reply With Quote
Old 03-24-2021, 07:21 PM   #22
Brocoli Wad
Brokoli Wad,
Came with the truck. They probably are car rims that were installed with the “disc conversion” PO did.
It was an artistic junkyard swap.
Old 03-24-2021, 09:10 PM   #23
Overdriven
Brokoli Wad,
Wheel Vintiques has “car rally’s” in 5x5 and 6 lug
1967 C10 LWB 250 6cyl 3ott Panaramic cab “Layla”
1967 Camaro 327 ‘glide cruiser “Bailey”
Overdriven is offline   Reply With Quote
Old 03-24-2021, 10:24 PM   #24
Gigem
Gigem's Avatar
If it were my truck...
flip the tires so no white letters show, and add the beauty rings
1972 GMC Sierra Grande (current truck)
1980 Chevy Stepside (gone)
1987 Chevy Blazer (gone)
1972 Chevelle SS Convertible (gone)
1973 Chevy Corvette (gone)
1967 Chevy Camaro (STOLEN!)
Gigem is offline   Reply With Quote
Old 03-24-2021, 10:28 PM   #25
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Which way would you go?
This was back in 1986/87 time frame. My truck has seen 2 other sets of wheels and tires since then.
15" x8" all 4 wheels. Trim rings are a must if you run the Ralley wheels. They just don't look right without them. Sorry about the pictures they are pictures of old 35mm camera pictures.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
