Re: 1987 R10 4/6 Drop
Found this thread since I have an '87 that I'm about to be lowering. To hopefully help others not run into issues, I just wanted to correct the tire size mentioned above ^^. I suspect the OP is running 255/70-15 as that is right at 29.1" diameter not the listed 255/75 which would be nearly at 30" overall diameter. I'm currently on 265/70-15 (29.6") so sounds like I might be able to get away with a drop similar (but not quite) what the OP has, which is great to know! Last edited by slalomsauce; 03-26-2021 at 02:59 PM. |
| Bookmarks |
