Old 03-26-2021, 09:22 PM   #1
skip99
skip99's Avatar
Re: Door window felt and trim
Originally Posted by MiraclePieCo View Post
I've done several of these. The T rubber goes in the slot on the outer bottom of the window opening. It is often an extremely tight fit and requires a liberal amount of soap or lubricant to get it to slide. You may even have to pry the slot open a bit.
The felt piece goes on the opposite side of the lower window opening - the inside bottom. It can be bent to conform, but if it's still too long there is no problem in trimming it shorter with some side cutters. It can be secured with your choice of screws, glue, or rivets. It's really just an anti-rattle device so an exact fit isn't crucial.
One thing that's curious: your rubber window sweeps appear to be two different configurations. When viewed on end, one is the T-shape, the other a triangle shape. Each of these is commonly used, but why did they send you a mismatched set? They should both be one shape or the other.
There is two of each on the outside rubbers, only one fits, the left one is too big but like you said, might fit if i bent the track,
Tami's 51 build
http://67-72chevytrucks.com/vboard/s...d.php?t=428878
skip99 is offline   Reply With Quote
