Re: 2.73 rear end
The very low ratios were usually paired with the straight six engines. Those engines are torque monsters, particularly right off idle, but they don't rev high. I would look into a built 292, with an emphasis on bottom-end torque instead of HP. It should feel and drive similar to a diesel when all's said and done. A manual transmission will make it all the better.
I'm driving a bone-stock 1981 2wd f150 with a 300-i6, four-speed manual, 2.73 gears, and 28" tires. It's a hoot just tooling around local country roads. The bottom-end torque is unbelievable, and fuel economy is pushing 20 mpg on longer trips.
1987 C6P V20 truck, 2010 LMG 5.3, AFM delete, 2010 Camaro exhaust manifolds, 1997 nv4500, 1991 np241c, hydroboost, 2005 14bff axle & driveshaft, drop-n-lock gooseneck, 4.10 gears, stock suspension, rims, and tires. Still a work in progress. Any questions or suggestions are welcome! |
| Bookmarks |
