03-20-2021, 04:56 PM | #1 |
1972 GMC Power Steering Pump bolt leak
I have a leak from one of the lower pump mounting bolts. There appears to be a white plastic like washer/seal between the hex nut and the pump body. I plan to replace it with a new seal and flat washer to push the seal. Anyone have an idea what material seal I should use? see photo of pump backside. Thanks for any help
03-20-2021, 08:07 PM | #2 |
Re: 1972 GMC Power Steering Pump bolt leak
The seal (rubber) is between the tank and pump on the inside. Looks like someone is just trying to patch it up.
03-20-2021, 08:40 PM | #3 |
OK - I am not sure what seals I need and where they go. Where can I get an exploded view with parts list? thanks for your halp
03-20-2021, 11:11 PM | #4 | |
https://www.oreillyauto.com/shop/b/s...+seal+kit-pump |
04-01-2021, 11:00 AM | #5 |
There's also the Edelmann 7910. I'm sure any rebuild kit will be fine
72 C10 lwb fleetside -stock 350/350 combo |
04-01-2021, 10:15 PM | #6 |
I'm think I used thin copper washers to seal those spots years ago
