Old 04-02-2021, 08:34 PM   #876
IronCanine
I'm trying....
IronCanine's Avatar
Re: 67 GMC super custom build
That looks good.
IronCanine is offline   Reply With Quote
Old 04-05-2021, 02:34 PM   #877
chewychevy67
After pulling the cowl off and on a few times the screws that go into the sheet metal always stretch the metal out and they became hard to tighten down . Here is the fix. Keeps the cowl and hood aligned better too when it's all in good condition.
chewychevy67 is offline   Reply With Quote
Old 04-05-2021, 02:38 PM   #878
Kronald_70GMC
Kronald_70GMC's Avatar
That is a great idea. Do you think that these would work as well?
Kyle
1970 GMC "Project Splice"
2017 Yukon Denali (Daily Driver)
IG: kyle_ronald
Kronald_70GMC is offline   Reply With Quote
Old 04-05-2021, 03:00 PM   #879
chewychevy67
Yes you could but won't use them. Aluminum on metal I don't like and I'f you strip it you have to drill it out to replace. If you strip the clip you simply replace it.
Old 04-05-2021, 03:02 PM   #880
Kronald_70GMC
Yeah that is a good point. I like that idea
Kyle
IG: kyle_ronald
Old 04-05-2021, 07:17 PM   #881
chewychevy67
I also cut the hole into the cowl for the cold air piece just like the factory did it. First pics are from the truck that this set up came off of factory.
Old 04-05-2021, 08:57 PM   #882
bertvert72
bertvert72's Avatar
That's is cool. I have never seen that option. Have you got a picture of it all together .
Bret
Here's a link to my build
http://67-72chevytrucks.com/vboard/s...d.php?t=577889
bertvert72 is offline   Reply With Quote
Old 04-05-2021, 10:43 PM   #883
chewychevy67
Here's what it looks like. This is mocked up on my truck. The hoses are not original. The air cleaner is not correct I this photo. The bottom one has it In it
Old 04-07-2021, 09:58 AM   #884
jaros44sr
jaros44sr's Avatar
That is a sweet setup, it may be the answer for my TPI set up, what is it from, I will have start looking for one
Ps, I always follow your thread, just don't post up
Great build
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 04-07-2021, 12:53 PM   #885
chewychevy67
The air cleaner setup is a option from 63 to 68 possibly 69 gm trucks. Rpo K46. Was probably mostly found on larger trucks but was available on all of them except tilt cab I believe
Old 04-07-2021, 07:45 PM   #886
IronCanine
I'm trying....
IronCanine's Avatar
Rod...c'mon....you are killing me. That is ridiculous AND AWESOME. Where are you coming up with this stuff?!! I keep thinking you have got to be done with mods...but nope. BAM!! Hit em again.
Old 04-07-2021, 08:56 PM   #887
chewychevy67
I'm all out of mods now. Cab goes for metal work in May so that is the beginning of the end. Then assembly!
Old 04-09-2021, 06:01 PM   #888
chewychevy67
I bought these clips from 60s car and routed my washer hose inside the cowl. They mount with the screws that mount the wire gutter so you won't notice this too much. Also my washer pump is now engine bay mounted so the hose will travel under the fender lip and go into the cowl on the lower right side.
Old 04-19-2021, 01:46 PM   #889
StingRay
StingRay's Avatar
These are available in steel. I have a hand tool and a pneumatic tool for installing them.
Saskatoon, Saskatchewan
Canada
StingRay is offline   Reply With Quote
Old 04-21-2021, 09:29 PM   #890
clay68c10
clay68c10's Avatar
Those nut rivets are awesome. I’ve used a few on my truck and several on the Jeep.
I have the Cornwell tool for install. It works well, you can use a drill or a hex driver.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO
http://67-72chevytrucks.com/vboard/s...d.php?t=788602
93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday...
05 Jeep Wrangler Unlimited. 3” lift & 6-speed
02 E320 the insurance total “free car”
13 Tahoe LTZ
clay68c10 is offline   Reply With Quote
Old 06-29-2021, 12:58 PM   #891
chewychevy67
Well I decided that I didn't really like the oak all that much. It's very common and it wasn't the finished look I was looking for. So today I got my new wood. Curly maple. A little more design to it. So it is still raw. I am going to attempt on the scraps I have to stain it charcoal grey like the picture below. Should pop nice with the stainless straps.
Old 06-30-2021, 09:53 AM   #892
88Stanger
88Stanger's Avatar
Love that Curly Maple, but damn that stuff can be expensive, but oh so worth it. Nice job sir!!!
John 3:16 - Saved me... God Bless
88Stanger is offline   Reply With Quote
Old 08-13-2021, 01:31 AM   #893
chewychevy67
I had jason do my curly maple boards and it was nice cause he Is local to me and saved some shipping . We had a mix up on the boards that the frame bolts go thru and he milled the holes quite a bit larger than they are supposed to be...... but he remade those 2 boards for me with no fuss and was great to deal with so if your in need of bed wood in the north this guy is a good resource to look at. https://www.hindsightbedwood.ca/
Old 08-13-2021, 01:43 AM   #894
Kronald_70GMC
Very nice! Can't wait to see the wood finished.
Kyle
IG: kyle_ronald
Old 09-09-2021, 06:36 PM   #895
chewychevy67
My cab repair started today! Hope I have a better experience this time from the last time. I did my homework this time and waited in a long line of ppl who all recommended him so I feel much better about this time. He says in a couple week he should have it completed and then it will get sealed. I'm so excited. I'll post pics of it if I can get him to send them to me.
Old 09-09-2021, 06:37 PM   #896
Kronald_70GMC
My cab repair started today! Hope I have a better experience this time from the last time. I did my homework this time so I feel much better about this time. He says in a couple week he should have it completed and then it will get sealed. I'm so excited. I'll post pics of it if I can get him to send them to me.
Who did you go with this time?
Kyle
IG: kyle_ronald
Old 09-09-2021, 06:39 PM   #897
chewychevy67
I got Todd from crusin metal to do it.
Old 09-09-2021, 06:41 PM   #898
Kronald_70GMC
Is that out of province?
Kyle
IG: kyle_ronald
Old 09-09-2021, 06:45 PM   #899
chewychevy67
No. He used to be in warman but He built a shop on his acerage between Martensville and saskatoon. He only does vintage vehicles. Lots of the vehicles at the draggons he Has done. Threefourty-six in warman will be painting it.
Old 09-09-2021, 06:47 PM   #900
Kronald_70GMC
Awesome. Sounds like a way better deal than the last go round
Kyle
IG: kyle_ronald
