Front axle questions
72 Blazer front passenger bearings went out (bad).
I took the wheel off, took the lockout off. It was toast behind the lockout. I have not taken a 72 front end apart so I didn't know what to look for. I then took the brake caliper off and the rotor came off with no problems. After doing some reading, I should of had to take some other stuff out before the rotor came off. There were barrel style bearings still inside the rotor/housing, but the pack itself was gone. I've got the whole axle out now and the problem I'm having is I have one "gear" still hung on the end of the outer axle and I cannot get it off. There is no clip on the axle and I'm wondering if the outer teeth are twisted now. Does anyone have a diagram or pic of an outer axle assembly so I can see what went where?? Thanks
1966 Chevy C-10 1970 Chevy K-5 Blazer 4x4 1972 Chevy K-5 Blazer 4x4 2003 2500HD GMC Duramax/Allison 4x4 Full 4 Door |
Next!
Hope this helps!
86 K30 CUCV M1028A1 86 K30 CUCV M1028a2 dually 86 K30 C&C 6.2 4:56s, 4M, 11,000 gvw, ex fire truck, now lowboy dump More square bodies and CUCVs than I care to admit to 2020 Silverado K3500HD Work truck |
Thanks!!
That's perfect. I need to find one of those high dollar manuals
