Old 04-07-2021, 09:06 PM   #1
Rich72C10
Mr. Cheyenne
Rich72C10's Avatar
Question Water Pump Plugs - Best Way to Seal Them?
So got a new ACDelco Professional water pump and there are two holes I need to cap off, I have the brass plugs but what is the best/proper way to seal them from leaking?
A ton of Teflon tape?
Pipe dope?
Thanks - I don't want leaks!
<searched for the answer, guess I am stupid and the only that doesn't know>
Richard
'72 Chevy C10 Cheyenne *Super WHT/MED BRONZE/WHT
SBC 350 | TH350 | LWB | AC | Buddy Seats
Upgrades: Tilt | Front Sway Bar | Radio | Sliding Window | Bed Spare w/Lock
Bed Rails | Full LEDs | Courtesy Lights | Tachometer | Glovebox Lock & Light | Head Light Relays | *Upgraded Fully Super Trim
Rich72C10 is offline   Reply With Quote
Old 04-07-2021, 09:36 PM   #2
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Re: Water Pump Plugs - Best Way to Seal Them?
I use teflon pipe compound, then wrap a couple layers of teflon tape over the compound. No leaks.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Old 04-07-2021, 09:42 PM   #3
Rich72C10
Mr. Cheyenne
Rich72C10's Avatar
Hmm teflon tape compound ... going to look that up. That I don’t have.
Richard
Old 04-07-2021, 09:49 PM   #4
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Teflon pipe compound is just pipe dope made with teflon. Any hardware store will have it and teflon tape in the plumbing section.
- Mike -
RIP El Jay
Old 04-07-2021, 10:02 PM   #5
Steeveedee
Who Changed This?
Steeveedee's Avatar
Any good sealant will do the trick; you don't need anything special. I've used #1 and #2 Permatex, blue and black RTV, Indian Head shellac, whatever I had on hand. If it were mine, though, I'd use plugs with a 3/8" square drive or hex that is inset. Don't need that big ugly head sticking out...
~Steven
Simi Valley, CA
Old 04-07-2021, 10:03 PM   #6
Rich72C10
Mr. Cheyenne
Rich72C10's Avatar
Orileys didnt have any innies :-(
Richard
Old 04-07-2021, 10:11 PM   #7
jocko
jocko's Avatar
I've always used just teflon tape and nothing else - never leaked. Amazon will have 3/8 drive pipe plugs to your door in 24 hrs, it's worth the wait (I agree w/Steveedee's note on the plugs)
Old 04-07-2021, 11:47 PM   #8
Rich72C10
Mr. Cheyenne
Rich72C10's Avatar
You guys are killing me.... ordered for both holes - Brass Pipe Fitting, Hex Drive Countersunk Plug. One is 1/4 and the other is 3/8.
I think I'll do a good wrap with Teflon Tape - I have tons of that stuff laying around.
Richard
Old 04-08-2021, 01:14 AM   #9
kwmech
Snug them up but do not over tighten them, you can crack the pump housing when using teflon as a lubricant
Old 04-08-2021, 01:32 AM   #10
Warrens69GMC
Warrens69GMC's Avatar
Don't care if they come out again? Black or Blue silicone ...
1969 307, t350
1950 Chevy Wagon
1978 Big 10
1967 C10, 250,3-OTT
Old 04-10-2021, 05:34 PM   #11
Rich72C10
Mr. Cheyenne
Rich72C10's Avatar
The Right Stuff Black sealed with innie plugs, primed and painted! Time to dry, then install!
Richard
Old 04-11-2021, 11:08 AM   #12
Rich72C10
Mr. Cheyenne
Rich72C10's Avatar
Installed - so far no leaks and no more squeaks!
Richard
