71 C10 Manual Transmission Mount
Having a hard time finding transmission mounts for a 71 C10 with 307 motor with a standard transmission (3 on tree). I’m thinking of just putting the original mounts back on, even though the rubber is dried out and they are showing their age.
I talked with Tech at LMC and he indicated there seems to be an after market mount that does not resemble this part at all. If any members have replaced them and remember where you got them, it would be great to know. I did a search here and did not find any info relating to these mounts. They are on a crossmember, one on each side, the mounting block resembles a “C” with a large center hole that sits on a hole in the crossmember and two bolt holes in the mount for securing to the transmission. Does the same mount work for both manual and automatic transmissions? Parts sites don't seem to distinguish or ask if manual or automatic, and only show one mount, and that appears to mount on the center of the crossmember. Not sure how that would bolt to the transmission though. Any help or info appreciated. The crossmember, circled in red are the location and one mount: The Mount, top and bottom: |
![]() Join Date: Dec 2013
Re: 71 C10 Manual Transmission Mount
Ebay $65.00 a set I think I saw them in Classicparts also
https://www.classicparts.com/1954-84...info/79%2D111/ rubber https://www.classicparts.com/1954-84...info/79%2D161/ poly
![]() 1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
They should be available at any parts store. The same one was used for many years. There is also a small mount that goes underneath the frame. There is a bolt & spacer sleeve that holds it all together. Often they have fallen out & are missing. The auto tans models are different.
George |
Thanks Grumpy & George, will search around. Wonder why they are called an engine mount. Looks like you have to drill and tap new holes for bolting on.
#5 | |
Just for general knowledge the 6 cyl and V8 manual cross members are different and mounted in different positions .
stock bell housing
Very good Grumpy, thank you, will do.
I found them under rear engine mount, since manuals are not mounted to a cross member, they just bolt to the bell housing, which is resting on said rear engine mounts. You can see it very good in Grumpy's pic. That's why when you search for trans mounts, all that comes up are mounts for automatics.
'64 C10 LWB, 283, 5speed '68 C20 LWB, 327, 4speed '69 C20 Custom Camper Longhorn, 350, 4speed '72 C20 Cheyenne Super, 396, TH400 '66 C60, 292, 4speed |
Still Green but learning
Resurrection of this one, I need to replace the clutch on my 3 speed and I am going to do the gaskets on the gear box while I am at it. Looking under there planning and I see the transmission mounts have a little clip on them. I guess it's designed to keep the bolts from backing out. How do I get those bolts to back out of that mount do I remove the clip somehow?
-- Cory 71 Cheyenne 10 - SWB, 350, "3 on the tree" AC cab 07 Suburban LTZ 4x4 2010 Acura TL 98 Mastercraft "FrankenStar" 225 27253 UPS/USPS IIOY....nope never was |
#10 | |
