#1 | |
I’ve read a lot of debate on ported versus manifold vacuum. I know by going to manifold I could reduce initial, but wouldn’t that defeat my quest for more total? The Progression looks like a nice unit and would no doubt be fun to play with. However I’d rather not spend hundreds on a distributor right now and besides, I’m having too much fun learning and playing with the old-school analog one I already have. Thanks again. Posted via Mobile Device |
#2 | |
Re: Ignition Timing
Next question is why is your idle set so high? I've got a street/strip cam in my 383 and it idles at 800 when hot. A tamer build with an RV cam ought to idle fine below that... And you dont have to reduce the initial w/ manifold vacuum but you had mentioned you were coming into starter issues at 16. It just allows you to run lower initial but with the vacuum advance in play AT idle you will have a peppier engine. If you cant get the advertised 20* in the chart i'd try another product, personally. That's your true issue. Unless for some reason you have limiter bushing in place that should be smaller to allow for more mech advance... |
#3 | |
My starter problems begin at 18, no problems so far at 16. I haven’t seen anything that should limit distributor travel. I am going to try a different product. Morosso seems to make a quality kit. I’ll look deeper. Appreciate your help! Posted via Mobile Device |
#4 | |
Re: Ignition Timing
#5 | |
#6 | |
Re: Ignition Timing
First for your carb you want to make sure the idle set screw is set so that your transfer slots look like squares when viewed from the underside. If you've played with this screw to set your idle speed you may induce an off idle stumble if the transfer slots are overexposed. Then set your initial timing to achieve the idle rpm you want. Larger cams will need more initial. Then you set your idle mixture screws in drive simply because that's where you need the right mix, in drive ready to drive the car, with a load on the engine from the torque converter. Then set your idle mixture screws for best/highest vacuum. All of this has less to do with exhaust smell and more with optimizing the AFR at idle and this is how you do that short of an AFR gauge.You may very well have the right tune on your carb/distributor but this is how you do it from square 1. |
#7 | |
