Old 04-12-2021, 06:21 PM   #29
Rich72C10
Mr. Cheyenne
Rich72C10's Avatar
Re: Value of compressor clutch flyback diode
I think, the more amperage the diode can handle the longer / less likely it will get blown. say for a unusual spike. Since it has to be "beefer" to handle more current (amperage) it cost more. To us, replacing one isn't a big deal (though I'd be surprised if you could just buy one). But for GM, that fraction of cost more could have made them use smaller/larger as time went by - if in fact the values were changed. Or if they went up in amperage they found the diode needed to be beefer to be more bullet proof.
Or that is my take little solid state parts - when if comes to amperage difference alone.
I used to do some side work in East Texas and kept a dirt track's time lap board working. It was a pretty simple board where the lights were (more or less) 120v 100 watt light bulbs. The darn transistors were always blowing and when enough died I was called out before race night to repair it on the spot.
My dad helped me at the beginning and told me the transistors were way underpowered and I needed to go "x" to handle a better load and not be so prone to spikes (the whole setup/building could have used better grounding too) - he actually had a crap ton of them on his peg board. I said, then I'll not have easy money anymore and free race night! Perhaps a bit dishonest but I wasn't the one that designed the thing - I replaced it with what the manufacturer called out in the schematic. On a happy note, my last repair I replaced them all with what my dad suggest as I was moving to Austin. I slammed a proper copper ground rod off the garage for a proper direct ground. Far as I know, that thing never died again.
Though my point is, don't sweat the 1N400X value. Granted I suppose you could go to big and somehow blow up something up with a crazy big spike but I could not image that happening with this diode - plus that is what a fuse is for - not a diode.
Richard
'72 Chevy C10 Cheyenne *Super WHT/MED BRONZE/WHT
SBC 350 | TH350 | LWB | AC | Buddy Seats
Upgrades: Tilt | Front Sway Bar | Radio | Sliding Window | Bed Spare w/Lock
Bed Rails | Full LEDs | Courtesy Lights | Tachometer | Glovebox Lock & Light | Head Light Relays | *Upgraded Fully Super Trim
Rich72C10 is offline   Reply With Quote
clutch, compressor, diode
