![]() Join Date: Apr 2017
Pertronix Advance
Can someone help me with a question for a Pertronix distributor? With a 350 with an RV cam, where should I start as far as springs and advance limiters? Should I lock out mechanical advance and rely on vacuum advance?
1969 GMC K25 2007 Chevy 2500HD Classic Duramax 1999 Tahoe 2DR 4WD Base Model 5.7l |
Re: Pertronix Advance
It depends on your set up.
A stock versus modified thing. Stock motor might like a lazy timing curve and a modded motor might like something more aggressive. What motor, cam, heads, intake, carb, trans, rear gear ratio all play a part. How is yours set up? |
Stock motor with Edelbrock intake and carb. Believe it’s an RV cam. SM465 trans. 3:73 gears an 33” tires. Loves to pull from low RPMS
What’s your initial timing set at?
That’s the best place to start. |
It likes 13 deg btdc
Is your pertronix completely adjustable?
Usually you want total timing (mechanical+initial) to be near 32 degrees all in by 3200 rpm. With your 13 you’ll want about 20 mechanical. |
Yes. Different springs and limiters came with it.
![]() Join Date: Oct 2005
Do not block off the mechanical advance.
George |
Did you get charts with it to tell you what springs etc to use for desired settings.
You’ll likely want it to be fairly lazy to begin with. You’ll need to experiment to see what your motor likes. I’ve got a motors manual here with distributor specs. Would you have the original distributor with part number. |
Mr. Cheyenne
![]() ![]() Join Date: Jun 2020
may want to take a look at my thread (page 3), I put my all in at 25K with the springs that are included.
https://67-72chevytrucks.com/vboard/...=818178&page=3 My Truck, from post1 SBC 350 Rebuilt less than 1k on engine at this posting.
Richard '72 Chevy C10 Cheyenne *Super WHT/MED BRONZE/WHT SBC 350 | TH350 | LWB | AC | Buddy Seats Upgrades: Tilt | Front Sway Bar | Radio | Sliding Window | Bed Spare w/Lock Bed Rails | Full LEDs | Courtesy Lights | Tachometer | Glovebox Lock & Light | Head Light Relays | *Upgraded Fully Super Trim |
