Old 04-14-2021, 08:12 AM   #1
kens65fb
Rear Coil Spring removal?
I'm about to install rear drop springs in my 64.
I was able to remove the upper coil spring retainer and bolt without too much trouble, but the lower retainer gave me fits.
I raised the frame to get the tension of the spring, and it was clear by about an inch.
I was not able to get a socket on the lower bolt as it was partially recessed into the control arm, is this normal?
Should there be a washer between the bolt and the control arm
How do you remove the lower retainer??
kens65fb is offline   Reply With Quote
Old 04-14-2021, 09:15 AM   #2
roll_the_dice
roll_the_dice's Avatar
Re: Rear Coil Spring removal?
I've been thinking of changing my springs too and it always looks easy, but 50+ years of those bolts hanging on makes it tough I am sure. I am sure you have seen this, but you can see he struggled too...spring removal starts at around the 3:15 mark.
roll_the_dice is offline   Reply With Quote
Old 04-14-2021, 09:28 AM   #3
kens65fb
chevy c10 4''drop on rear - YouTube
I did watch that video, and he was able to get a socket on the bottom bolt.
The bottom bolts on my springs , are partially recessed into the control arm, and I cannot get enough of a bite with a 3/4 socket.
Old 04-14-2021, 09:53 AM   #4
The Rocknrod
Moderator
The Rocknrod's Avatar
Your going to havle to cut them out or drill them out. Maybe drill the heads off?
I'd remove the upper bolts, the trailing arms bolts (to the cross-member) and work on them off the truck. But that's just me.
Old 04-14-2021, 10:52 AM   #5
kens65fb
I wonder if there should be some type of washer between the bolt & control arm, so the bolt doesn't bury itself, then you can get a socket on it.
Old 04-14-2021, 10:53 AM   #6
The Rocknrod
Moderator
I would.
Old 04-14-2021, 11:03 AM   #7
pdxhall
pdxhall's Avatar
If the bolts are as you said, you will probably need new lower spring perches and bolts. If the hole in the control arm is buggered out a washer may work but you will know what's going on when you get it torn apart. I cut mine out and replaced everything.
Sanity'66
http://67-72chevytrucks.com/vboard/s...d.php?t=515110
Long bed, Fleetside, Small back window
I've Done So Much, With So Little, For So Long, That Now I Can Do Anything With Nothing.
pdxhall is offline   Reply With Quote
Old 04-14-2021, 11:03 AM   #8
roll_the_dice
That's a good idea...beats laying on your back doing it!
Old 04-14-2021, 11:52 AM   #9
lolife99
67-72 parts collector,…
lolife99's Avatar
I always start rear spring removal but cutting the spring with a cutoff wheel and getting it out of the way.
Remove the shock and lower the rearend so you can get in there and work.
Everyone tries to save the old spring.
Make things easy on yourself.
Just my 2 cents.
Keith
Convert to disc brakes.
Old 04-14-2021, 12:28 PM   #10
cwcarpenter98
cwcarpenter98's Avatar
I have a washer on the underside of the spring bolt that goes through the trailing arm.
After 50+ years, the washer could have rusted away or broke apart
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed
1995 Dodge Dakota Sport
Old 04-15-2021, 06:36 PM   #11
Heater63
Heater63's Avatar
Everything needs to be replaced with NEW, so cut everything...torch or wheel.
292 + TKO500
Heater63 is offline   Reply With Quote
Old 04-15-2021, 11:38 PM   #12
Riverstory
Riverstory's Avatar
I used a breaker bar with a 4' cheater pipe. Came right off. No sense in cutting when you don't have to.
Riverstory is offline   Reply With Quote
Old 04-16-2021, 04:08 PM   #13
forestb
forestb's Avatar
Have you tied spinning the coil. If you can spin the coil and the bottom bolt stays in place then you should be able to get it out.
forestb is offline   Reply With Quote
