Old 04-19-2021, 07:41 AM   #1526
youngrodder
youngrodder's Avatar
Re: 53 Surburban "Family Truckster"
Well I fired the motor this weekend. This time it fired right up just like on TV. No issues. That is how the first start up was supposed to go. No I can start assembling the rest of the front sheet metal.
I also hung the rear doors complete with seals and functioning latches and door hardware. The Suburban back door latches and hardware they don't reproduce. I reconditioned mine and modified a side door handle to work for the back doors. Very pleased how well they shut and seal.
Full speed ahead. Looking for a late spring test drive...
Marc
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is online now   Reply With Quote
Old 04-19-2021, 07:51 AM   #1527
ajgriffin
ajgriffin's Avatar
Marc
CONGRATS!!!
69 C10 SWB -- Left to me by a loving father. Finishing the build we never got the chance to do together
ajgriffin is offline   Reply With Quote
Old 04-19-2021, 08:11 AM   #1528
6DoF
6DoF's Avatar
Can you tell I soured on DD??
Marc
they look amazing and really have a lot of the bases covered, but for the money i keep leaning further away. for the Cummins i was looking at $2000-2500 and there was zero option for data logging. that was a deal breaker for me.
6DoF is offline   Reply With Quote
Old 04-19-2021, 08:43 AM   #1529
8man
That's a big day! Congratulations.
8man-aka Robert
1948 on a S10 Frame, small block with a carb
1954 Cab, 53 Front and Bed, 50 Doors, S10 Frame, Power TBD
Build thread: "]http://67-72chevytrucks.com/vboard/showthread.php?t=746899&highlight=wife%27s+48[/URL]
[/URL]http://67-72chevytrucks.com/vboard/showthread.php?t=840204
8man is offline   Reply With Quote
Old 04-19-2021, 09:14 AM   #1530
youngrodder
Originally Posted by ajgriffin View Post
CONGRATS!!!
Thanks I was stoked..
I worked on hooking up the new module (GSS-3000) so my gears now display. I may to sell the module that I'm not using.
Thanks, I need to hook up my throttle cable so I can bring up the RPM's to hear the exhaust better. I like what I have heard so far.
Marc
Old 04-19-2021, 09:39 AM   #1531
Tempest67
Tempest67's Avatar
a milestone day for sure , Congrats
Tempest67 is offline   Reply With Quote
Old 04-19-2021, 10:13 AM   #1532
oldman3
oldman3's Avatar
Marc, congrats on the start up, can't wait for the test drive...Jim
oldman3 is offline   Reply With Quote
Old 04-19-2021, 11:26 AM   #1533
youngrodder
Thank you
You and me both Jim.....Waiting on a drive shaft that I needed shortened. Should be done in about a week.
Marc
Old 04-21-2021, 05:13 AM   #1534
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Congrats on the no issue first start up! That's always a great feeling!
Ryan
1969 Chevy milk truck
Old 04-21-2021, 07:59 AM   #1535
youngrodder
No, this was the 2nd test fire. The initial one crated major issues from a stuck open injector. I think I had PTSD from the first start attempt. Attempt #2 went off smooth...
Marc
Old 04-21-2021, 09:06 AM   #1536
olcarguy
Awsome....starting to see the light at the end of a long tunnel....
olcarguy is offline   Reply With Quote
Old 04-21-2021, 09:31 AM   #1537
youngrodder
Thank you....
Marc
Old 04-21-2021, 11:41 PM   #1538
lower50's
lower50's's Avatar
Congratulations Marc!! It's always funny when you see the "first start" on tv. You will have to have a pole to see weather your green truck or this truck wins lol.
http://67-72chevytrucks.com/vboard/s...d.php?t=648459
https://67-72chevytrucks.com/vboard/...d.php?t=769441
1951 MG TD
1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers.
1952 GMC 9700 p/u 7.3L diesel on air, dually
lower50's is offline   Reply With Quote
Old 04-22-2021, 10:37 AM   #1539
youngrodder
Thank you...I'm guessing the green truck would win in a landslide. I think most people around me that knew the green truck wont "get" the look of the Suburban. When in reality this Suburban is a so much nicer build in many ways (minus paint) than the green truck.
Dropped the wheels off this morning to be mounted/balanced. Picked up my carpet and last of the upholstery last night and I go to pick up my drive shaft tomorrow...
Marc
Old 04-26-2021, 09:27 AM   #1540
youngrodder
I installed my driver seat (temporarily) to allow me to mount my throttle pedal and cable. I was fearing the worse with the throttle pedal as I needed to make a mount and since my firewall was painted it had to be a bolt in solution. The mount I made years ago was a weld on solution. I was pleased how well it all turned out. Most people that use these throttle bodies to simulate a carb use the drive my wire solution. For this reason, I needed to make my own bracket to hold the throttle cable. It turn out very clean. And get this.......it works great!!
So I fired the motor again with a throttle cable which allowed me to rev on it. I was blown away at how bad ass this motor and exhaust sounds. I laughed that I screwed up and build a race truck..ha ha. I will post a video on my IG page (Greenfield_speedshop) later this week. Even my 16 yr old son ran out to the garage for a closer look. That can attest to how good its sounds to get a 16yr old to react that fast. ha ha
This was the first time I sat in the seat in the Suburban. The seat is so comfortable. Looking forward to some quality seat time this summer.
I also installed my driveshaft that I had shortened and picked up Friday.
Marc
Old 04-26-2021, 09:55 AM   #1541
8man
Very nice.
8man-aka Robert
Old 04-26-2021, 09:56 AM   #1542
Tempest67
Tempest67's Avatar
wow this looks so good.... love the seat, looks comfy.
Old 04-26-2021, 10:00 AM   #1543
Denee007
Denee007's Avatar
That is incredible!!!
dne'
'72 Ford Bronco project(July 17 2021-?)
https://67-72chevytrucks.com/vboard/...d.php?t=828015
59 Apache (sold 6-25-2021)
67 Ford Mustang (re-restored after Harvey)
1968 Jeep Cj5 (2-8-2020 to present)
1992 Jeep Yj (8-17-20 to present) (Jurassic build)
www.Classiccarsandtools.com
Denee007 is offline   Reply With Quote
Old 04-26-2021, 10:07 AM   #1544
youngrodder
Very nice.
Thanks man
I joke that the seats are more comfortable than how nice they look.
dne'
Thank you..much appreciated.
Marc
Old 04-26-2021, 10:33 AM   #1545
6DoF
6DoF's Avatar
that seat is so pretty, whole inside is looking amazing
Old 04-27-2021, 07:54 AM   #1546
youngrodder
Further assembly of the front end. Trying to take my time and hide as many wires and stuff as possible. I like how hidden the AC lines are. Next is to finish wiring the front end (lights, AC and fans).
I'm also chasing down a pesky fuel leak at one of my fittings by the tank on the supply side. I finally took the fitting off and retightened. I hope that solved it.
Thank you
Marc
Old 04-27-2021, 08:32 AM   #1547
6DoF
6DoF's Avatar
i hope my engine bay looks half as clean as that, super nice.
Old 04-27-2021, 09:03 AM   #1548
youngrodder
Thanks, I always try to apply the less is more approach and hide all of the unsightly crap. It takes way longer but you are left with a cleaner end product.
The vison I have had in my head for years is slowing coming into focus....
Marc
Old 04-27-2021, 06:36 PM   #1549
lower50's
lower50's's Avatar
It's a great feeling when your vision comes together as you where planning.
Great job!!
1951 MG TD
Old 05-06-2021, 07:45 AM   #1550
youngrodder
As I get closer to thinking about that first drive I have been busy getting this thing legal. I recently put insurance on it. I go today to order plates. Getting a appointment at ANY MI SOS is a choir in itself.
I installed my rear bumper with the aid of my son. I had my factory bumper brackets powder coated quite a while back with the satin black wrinkle finish.
We had to mount the bumper, get a placement for the hitch receiver hole. Unmount the bumper and then cut up said the new bumper. Then remount to check the hole placement....Spot on. I had done this process once before with a junk bumper so I had a general idea. The hitch receiver provied 2 functions. 1 - a lace to mount my plate. 2- Covers the hole in the bumper for the hidden hitch.
After that I gave the bumper a brushed finish (not pictured). I need to remount the finished bumper.
Marc
