![]() Join Date: Nov 2018
This might be a stupid question
Hello
After years of my old 65 sitting in a field in Texas it didn’t much for the front or rear suspension I’m looking to replace the panhard bar with rubber bushings and also rear leaf spring bar bushings they are completely shot on my truck. Does Moog make these parts I’m finding several Moog numbers for rear leaf spring bar and finding none for panhard bar any help greatly appreciate Thanks Pete |
![]() ![]() ![]() Join Date: Jan 2018
Re: This might be a stupid question
Do you have coil springs in the rear or leaf springs? The coil spring rear uses a panhard bar to center the axle. There's 2 arms that go to the front of the truck, but those aren't springs.
The leaf spring trucks don't have a panhard bar because the leafs also keep the axle centered
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
Hello
I got the bars Pete |
You'll need to be more specific. There are 2 rear suspension types: Leaf Spring & Truck Arm.
The T/A is an I-beam construction. Is that what you're calling "bars"? Truck Arm mount & Panhard Bar bushings: https://gmcpauls.com/Suspension.htm https://gmcpauls.com/pictures/6072re...armbushing.jpg
