Old 04-23-2021, 06:43 PM   #1
clemsonteg
American Autowire and glove box light
Question for those that have used the American Autowire kit, I’m not finding a spot for the wire. The manual says it’s a 12v battery fused for glove box, but even the lights I’m finding online don’t look like they use this connector.
clemsonteg is offline   Reply With Quote
Old 04-23-2021, 07:08 PM   #2
mongocanfly
mongocanfly's Avatar
Re: American Autowire and glove box light
Is the glove box circuit a separate option?..when I pulled it up it shows a light and switch for about 20bucks..
I've not seen a connector like that before
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 04-23-2021, 07:24 PM   #3
ray_mcavoy
That terminal should fit right inside the glovebox light socket / switch assembly. Goes right up alongside the bulb and one of the little "pins" on the base of the bulb hooks into the notch in the center of that terminal.
ray_mcavoy is offline   Reply With Quote
Old 04-23-2021, 07:53 PM   #4
The Rocknrod
Moderator
The Rocknrod's Avatar
Yes, thats what my glovebox light looks like.
Old 04-23-2021, 09:51 PM   #5
roll_the_dice
roll_the_dice's Avatar
I am about to buy a glove box light also...did you guys connect the hot wire to a battery or ignition 12v source?
roll_the_dice is offline   Reply With Quote
Old 04-24-2021, 10:54 AM   #6
TopFuel1966
TopFuel1966's Avatar
It depends on whether you want the light to come on anytime you open the door or only when the ignition switch is "on".
TopFuel1966 is offline   Reply With Quote
Old 04-24-2021, 03:21 PM   #7
roll_the_dice
What were they originally on anytime the box was open or only when the ignition is on?
Old 04-25-2021, 06:08 AM   #8
TopFuel1966
I bought a new C-10 in 1964 and the glovebox light came on anytime the door was opened. I've never owned a car that worked any other way.
Old 04-25-2021, 12:24 PM   #9
pdxhall
pdxhall's Avatar
That connector on the american autowire kit will fit into the kits accessory circuit that has several connectors both ignition powered and direct to battery powered. That is what I used.
Sanity'66
http://67-72chevytrucks.com/vboard/s...d.php?t=515110
Long bed, Fleetside, Small back window
I've Done So Much, With So Little, For So Long, That Now I Can Do Anything With Nothing.
pdxhall is offline   Reply With Quote
Old 05-01-2021, 01:17 PM   #10
Jurassic-1
Jurassic-1's Avatar
It has an accessory pig tail. You can put it in the spot for the cigarette lighter and plug that into the pigtail. it will come on with or without the ignition on.
Jurassic-1 is offline   Reply With Quote
