Old 04-22-2021, 09:56 PM   #1
DetroitIron
DetroitIron's Avatar
New starter jammed and blew something ?
Hi All
I installed a new starter that needed shimming and it jammed against the flywheel. I tried to start once too many before unbolting the starter and shimming. No crank know and bench tested starter to make sure it was still working. Any ideas on what might have burned up or how to trouble shoot? I’m not getting power to the starter
_______________________________________________
1985 Chevy Scottsdale K20 350 with 700R4 running 3.42 gearing aka "The Honey Badger"
1993 Silverado C3500 Ext. Cab Dually 6.5 turbo diesel
DetroitIron is offline   Reply With Quote
Old 04-22-2021, 09:57 PM   #2
DetroitIron
Re: New starter jammed and blew something ?
Checked fuses too.
Old 04-22-2021, 10:41 PM   #3
mongocanfly
mongocanfly's Avatar
Does your + battery cable go straight to the starter? ...or thru a junction block
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 04-22-2021, 11:09 PM   #4
Getter-Done
Getter-Done's Avatar
Check fusible link in the center of firewall , Under the hood.
The early bird gets the worm,
84 Chevy K-20
Old 04-23-2021, 07:53 AM   #5
DetroitIron
It goes directly to the starter...thank you
Old 04-23-2021, 09:38 AM   #6
mongocanfly
So you do have power to the starter...correct?
Maybe you meant no power to the solenoid from the switch..
Does all other electrical work?
Like stated above check the fuse link on the firewall..
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 04-23-2021, 12:41 PM   #7
DetroitIron
The positive wire from the battery runs directly to the starter but there is no power to the starter or solenoid...radio, lights, heater blower motor, and dash lights work....
Old 04-23-2021, 02:32 PM   #8
mongocanfly
Well..you should have 12v on the big lug on the solenoid...at a minimum...if not check the ground to the engine
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 04-23-2021, 05:18 PM   #9
DetroitIron
Yes I used a test light just now to confirm power at the alternator, bulkhead junction terminal, big positive lug on the starter AND what I think rules out a faulty ignition switch...the smaller wire that attaches to the S terminal on the solenoid has power when I turn the key to start. I bench tests the new starter and it is good as well. I will post some pics...I’m stumped
Old 04-23-2021, 07:21 PM   #10
mongocanfly
Yeah,that dont make sense...if you've got 12v on the big lug from the battery, and 12v from the switch to the S terminal when you turn key to crank position..it should go....have you tried a remote starter switch?..it would bypass the key switch...we use them to bump engines over...it just clamps to battery + and the S terminal on the starter..with a momentary button in the middle..
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 04-23-2021, 08:56 PM   #11
pound41
Try a new starter. I say that from experience. My nephew works at a store that sells carquest starters. He says they are constantly being brought back into with issues. I have had 2 of them one on 76 stepside 454 started it once or twice heard a clunk and it was done. Broke the housing. The other on my 71 blazer just fried. Order AC Delcos off Amazon Installed them both no issues
pound41 is offline   Reply With Quote
Old 04-23-2021, 08:59 PM   #12
DetroitIron
Thanks for the suggestion. It works fine bench testing it so I thought the starter is good?
Old 04-23-2021, 09:04 PM   #13
DetroitIron
Another question I’m researching is regarding the red fusible link that attaches to the main starter lug and goes back the cab connection to the fuse block. Since I have power in the cab in terms of radio, dash lights, etc....does it sound like the starter not cranking issue is not related to these wires?
Old 04-23-2021, 10:01 PM   #14
pound41
When we first started working on the 76 stepside. Its my Dad's truck who passed away. So it had been sitting. We had no lights power nothing. We worried about a chewed wire or something. Checked fuseable link, cleaned it etc. I thought the wire going from the starter to the junction box was broken. it wasn't. Since I had no power the starter was the last place I was looking. I finally checked the positive cable thinking it was bad. When I knew it was hot. I changed the starter from another truck and it started right up. Then I got the new carequest and put on it and it broke. I am have 71/72 blazers Positive to the starter positive lead to the junction box. Not running power to the starter and then feeding to the junction box. We chased wires for a while before we replaced the starter. Not much help to you I know but I wouldn't have thought a whole truck would have no power then you change the starter and everything works.
Old 04-23-2021, 10:13 PM   #15
DetroitIron
Very interesting. Thank you..I am going to return the starter and try a new one tomorrow thank you for the idea...maybe bench testing with no real world load of turning the engine over is different than being bolted in and trying to turn the sbc over...maybe something got cooked due to not being shimmed properly when it jammed into the flywheel and I kept trying to get it to crank. Lessons learned if that ends up being the solution
Old 04-23-2021, 10:15 PM   #16
1976gmc20
Well, I had a starter from my 76 that "bench tested" just fine but wouldn't turn the engine over. They tried to tell me my flywheel was bad. I took a chance and bought another starter and it worked just fine.
The thing is that there is no load on the starter gear when it just spins on the bench.
Back in the old days I never took back a starter for core refund. More than once I managed to take them apart and make one working starter out of two or three. That's handy when you're fifty miles from town.
Current/past Chevy/GMC trucks:
1958 Chevy C-60; 1965 GMC C-50; 1965 Chevy C-10; 1971 Chevy K-10; 1973 Chevy K-20; 1976 GMC C-20; 1977 Chevy C-10 Suburban; 1980 Chevy K-10; 1989 Chevy K1500; 1991 GMC V1500 Suburban; 2016 Chevy K2500 HD
Other vehicles: 1988 Jeep XJ; 2011 Toyota 4Runner
1976gmc20 is offline   Reply With Quote
Old 04-24-2021, 02:16 PM   #17
DetroitIron
Wanted to close out this thread with some goods and say thank you for the troubleshooting help here. I returned the starter first thing this am and the parts store manager ran it through a more detailed bench test. It was not working to spec, etc. but would spin. Got a replacement and used 3 shims to get the alignment correct. She turns over like a champ now. Still have some things to get back together and then new exhaust. Take care all!
Old 04-25-2021, 07:38 AM   #18
Glad to hear it is working again for ya.
