#76 |
I'm just glad to be here!
Re: kyb shocks/ part numbers
After re-reading thru this whole thread, I compliled the following spread sheet to get all this discussion into one post:
![]() Hope this helps everyone....
Karl ![]() 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
#77 |
Thanks aggie91,
I'm confused now more than ever.
#78 |
Looking for some rear shocks for my build and stumbled onto this great thread.
Bump
GOD BLESS AMERICA! |
#79 |
![]() Join Date: Jul 2009
Good info
1972 SWB Medium Olive South Houston Instagram: Antbish84 |
#80 |
After reading all the shock threads I went with the 344068 (front) and 344067 for the rear Both sets bought on Amazon for $74 shipped and free returns; cant beat that- I have a 64 c10 with bags no cnotch and my ride is terrible - I will report back when they arrive and I get them installed (if they fit)
#81 |
got the fronts on tonight only had to file down the socket housing slightly to get it to fit. The rears im going to need to do the same thing but they will need filing to fit. will report back this weekend.
#82 | |
67-72 parts collector,…
![]() Join Date: Nov 2002
Without them the shock angle is way too flat to make the shocks work.
#83 |
I believe I do - here is the picture I took after I soaked the Rears with Penetrating oil - From what I have seen those are shock relocation brackets. Also when I mocked up the new shocks they seemed to fit right in place, just needed to grind the eyes down to slide in.
#84 | |
Still riveted in from the factory.
#85 |
Thanks for the clarification; the shocks I purchased (344067) - that I think you mentioned seemed to fit right it. I will try and get under tonight and report back - if not by end of the weekend.
#86 |
They might fit but the angle keeps them from working correctly (even if they're better vs the current units). If you drop a truck arm equipped truck, you need to relocate the shock to a more 'upright' position.
#87 |
Good information - Since I haven't put them in I will order some relocators.
#88 | |
http://67-72chevytrucks.com/vboard/s...d.php?t=451200 http://67-72chevytrucks.com/vboard/s...d.php?t=359399
#89 |
New issue I have run into - the front right shock seems to bottom out before the front left when dropping my bags.....any idea on why this would be? Just bought front shock relocators so will be under there this weekend. Part number 344068 btw.
#90 |
One shock has slightly more resistance vs the other?
#91 |
C10 CLUB Y QUE!
What about if your running porterbuilt. Front and rear shocks?
#92 |
![]() Join Date: Mar 2000
I'm surprised none of our customers have responded as we've told all that ask.
ANY, I REPEAT AMY, shock that is made for your stock 1967-72 truck at normal ride height is ALSO the correct shock for those trucks with front & rear drop kits of ANY DROP Height. So if you use 1-5 1/2" drop in the front you still use the same shock. If you use 1-6" drop in the rear you still use the same shock. ECE, No limit, Classic, Brothers, everyone is selling shocks that are made to stick travel specifications. Now your asking why this is true. The reason is with any of the drops I listed above the stock shocks minimum & maximum travel distances are not exceeded. Since the shocks travel limits are still within spec, the stock shock length is still used. NOW in the rear once you hit about a 5" rear drop the shock has become to horizontal to absorb vertical travel effectively. So you then install rear shock relocators in the rear to make the shocks more vertical again so that they can then absorb the vertical travel of the truck. ( It's also my understanding though I have not tried it yet, that if you move the rear lower shock bracket from left side to the right, and the right side to the left this will also correct the shock angle back to a more vertical position eliminating the need for rear shock relocators. ) But again I've not checked this myself on just swapping the lower mounts from 1 side to the other. I'm just reporting what I've heard from several low budget builders. So everyone out determine the type of ride that you want based on you and your driving habits then look up the shocks and look for comfort, sport, off road etc.... based on your driving style & preference's and then purchase the stock shock for your truck in that type of shock. KYB GR-2 soft comfortable ride, KYB gas a just shocks give a firmer ride , etc..... Then buy from who you choose. If your already buying parts from 1 location and the shocks they have only cost a little more than the cheapest place you've found get the shocks from where your buying your other parts unless your getting free shipping. Hope everyone is Healthy, Happy, & Prosperous in 2016 and beyond. Paul @ GMCPauls |
#93 |
Wondering What you found out? I have a similar setup with a 66 burb
1961 Biscayne http://67-72chevytrucks.com/vboard/s...90#post6978790 SOLD 1971 C-10 http://67-72chevytrucks.com/vboard/s...d.php?t=656258SOLD 1966 Suburban http://67-72chevytrucks.com/vboard/s...85#post7323885 |
#94 |
just curious if anyone knows what numbers i should look for for a 76 with a 3/4 drop??
#95 |
Still Learning
This is an old thread, but I'm wondering how everyone likes their KYB shocks that they have installed over the years for lowered trucks?
#96 |
I installed the standard KYB Excel -G shocks (black) from the ECE lowering kit and wish I had upgraded to the Gas-Adjust (gray). The ride could be stiffer for a more sporty ride.
1972 GMC 1500 Super Custom, 383 Stoker, TH350 Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=592157 Engine Thread http://67-72chevytrucks.com/vboard/s...d.php?t=592233 |
#97 |
Bumping this great thread... Needing new front shocks and wanting to go back with KYB which is already installed, I was getting no traction until I found this thread. ECE, right now anyway, is gone. Just ordered a set of 344068's from Summit. EDIT: next day: got an email this morning stating that my new shocks are on the delivery vehicle. Guess it helps to live within an hour's drive of the SummitRacing warehouse! i would have burned more than the 10 dollars shipping cost worth of fuel to drive my BBC truck to pick them up! Happy Camper here. -klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold Last edited by weq92f; 04-02-2021 at 09:37 AM. |
#98 |
![]() Join Date: Sep 2019
I hate to add onto a old thread. But it's perfectly timed. I was wondering does anyone know the part number for the kyb's for a level 3 rear dropmember? I can find them with a eyelet/stud. But not an eyelet/eyelet.
Thanks!! |
#99 | |
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
#100 | |
However, it's still a bit soft for my liking so...I now realize I should have got the gas adjust version of these KYBs. Guess I'm going to order those now. Hopefully I can use these 344068s in the rear! -klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold |
| Bookmarks |
