Old 07-13-2004, 08:40 PM   #1
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Toddtheodd...dirt cheap 2 inch drop
This picture is older than my great grandaddy's buckskin condom.
It's my old 72, now my neighbors. 2 inch lowering blocks, I made at work one day. The u bolts were 27 bucks from Ft Worth Champion Spring on Henderson street.
Total cost under 30 bucks and 2 inch drop.
Wham, bam, thank you maam!
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 07-13-2004, 08:44 PM   #2
CG
BlahBlahBlah
is that wood?
Old 07-13-2004, 08:45 PM   #3
Tx Firefighter
Negative ghostrider, it's 2x3 inch .250 thick wall rectangular steel tubing. I just boxed the ends so it would look sexy.
Old 07-13-2004, 08:46 PM   #4
BIG ORANGE
BIG ORANGE's Avatar
That a boy firefighter,been doing like that for years and have never had a compliant! keep it up!
Things happen for a reason!
BIG ORANGE is offline   Reply With Quote
Old 07-13-2004, 08:49 PM   #5
CG
BlahBlahBlah
whew!!
Old 07-13-2004, 08:52 PM   #6
Tx Firefighter
Originally Posted by CG
is that wood?
Hey, I'm no hack. There's no way I'd make wood lowering blocks. Wood is best used for motor mounts and crossmembers.
A pine 2x4 makes a hell of a trans crossmember.
Old 07-13-2004, 09:27 PM   #7
FirstGen
Just Don't Stop!
FirstGen's Avatar
Damn good idea Jonny. I've been wondering what to do for a cross member for my 6 speed...
LOL!
1968 C10 build in process
TT LSA/6L90e/9"
FirstGen is offline   Reply With Quote
Old 07-13-2004, 09:29 PM   #8
Tx Firefighter
Who is Jonny?
Old 07-13-2004, 10:04 PM   #9
toddtheodd
The oddest Todd around
toddtheodd's Avatar
Now I understand better what you were saying.
Thank you for posting the pic. Looks fairly simple.
Todd
toddtheodd is offline   Reply With Quote
Old 07-13-2004, 10:22 PM   #10
68 Suburban
68 Suburban's Avatar
it looks great, but arent there safety issues if the ubolt/ trailing arm combo hang below the rim, incase of a blow out? I can't really tell from that pictue, but it looks like it is ok
Just sitting here contemplating contemplation.
68 Suburban is offline   Reply With Quote
Old 07-13-2004, 10:54 PM   #11
Tx Firefighter
68sub...yes, you are correct. Technically, you never want anything hanging below the wheel rim. That way, if a tire blew out, it won't dig into the pavement and bring you to a sudden halt.
I sometimes fudge a 1/2 inch or so on that though. Think about it, even if you completely deflate a tire, the wheel doesn't touch the ground. What I'm trying to say, is that even with a dead flat tire, a 1/2 below the scrub line still won't hit the ground.
The truck above has Early Classic shock relocators on it too though. They hang down a good bit lower than the stock lower shock mounts do. A good bit. Stock lower shock mounts, which is what todd will use, will be much higher. If he ground the u bolts off flush with the nuts too, he'd have a ton more clearance.
The truck above has 4 inch drop springs, 2 inch blocks, Early Classic shock mounts and panhard bar. Total 6 inch rear drop.
Old 07-13-2004, 10:59 PM   #12
FirstGen
Just Don't Stop!
FirstGen's Avatar
I just say Jonny alot...
TT LSA/6L90e/9"
Old 07-13-2004, 11:46 PM   #13
XXL
Seņor Member
XXL's Avatar
I beg to differ. Anyone using pine is a hack. If you're not using a hardwood (at least as hard as poplar or oak) you're going to get too much play and end up breaking something.
XXL is offline   Reply With Quote
Old 07-14-2004, 12:25 AM   #14
N2TRUX
Happy to be here
N2TRUX's Avatar
I won't try to make light of scrub line concerns because they are serious. I will say that they aren't as crucial in the rear. If you drag a fixed part in the rear you aren't as prone to loose control as you would if it were in the front....
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
