Old 04-23-2021, 07:49 AM   #2076
KMC3420
KMC3420's Avatar
Re: What did you do to your truck today.The 3rd chapter
Originally Posted by Ekliptix View Post
I re-sprayed my C10's door inserts with VHT Vinyl Dye. This stuff works amazing. I used it on my 70 blazer console with great success too.
And got some help cleaning the wheels from my 19 month old.
Door panels look great! Your little helper looks like my 2 YO son, he is my wheel washer man as well. You can’t tell them no, gotta get them involved young as they grow up too fast.
Keagan
68 SWB C-10 original 350 A/C 503 Mean Green
KMC3420 is offline   Reply With Quote
Old 04-25-2021, 10:29 AM   #2077
Rich72C10
Mr. Cheyenne
Rich72C10's Avatar
Talking Re: What did you do to your truck today.The 3rd chapter
Wished I had a helper when I was washing the truck yesterday LOL!
A few days ago I replaced my PCV valve. The one on the truck "seemed" okay, it rattled okay but I wondered about it. So I got a ACDelco Professional one. The one on my truck had a right angle on it, where as the ACDelco one is straight up (every part search shows this is the correct one). It definitely flows better when I blow air back and forth compared to the old one (I bought a elbow adapter so its not sticking straight up). Though the real test was driving around, way much better. The biggest difference is very low speeds, say under 25 MPH and you are barely giving any gas. Like you do (or should) when driving around a neighborhood full of kids running around. Before I'd have like a deadzone at this speed, like she didn't want to really go until I gave her more pedal.
After this, I did some vacuum hose rerouting. Bought a vacuum kit off Amazon with a ton of T-adapters of various sizes. I also cut the hoses so there isn't any extra flapping around. I think this helped too, since this was mainly the manifold to distributor advance line.
Now after letting all of that settle for about a week, I finally installed my divorced electronic choke. It mounts right where the OEM one goes, then has a sensor on the forward intake manifold bolt (for GND) and then I tied it to the Stop Solenoid power. Man, it is nice to watch that choke warm up and move the plate and hold it solid in place.
Oh, I also fixed a fuel pump oil leak, which I caused myself when I replaced my fuel pump a month or so ago. I did a crappy job by allowing the lower part of the gasket to fold onto itself at the bottom. Got to love re-doing stuff that you messed up yourself... but perhaps that is why two gaskets are sent with these pumps LOL!
PS: I was at Sonic last night and a fellow pull up in the next stall. He gets out, knocks on the passenger's window, scares the poo out of my daughter LOL. He asks, "do you mind if I take a photo of your Truck??". I say sure, I don't mind. Then he says, "Thanks, your truck is cherry!". That my friends made my day, heck even my week! Ha!
Richard
'72 Chevy C10 Cheyenne *Super WHT/MED BRONZE/WHT
SBC 350 | TH350 | LWB | AC | Buddy Seats
Upgrades: Tilt | Front Sway Bar | Radio | Sliding Window | Bed Spare w/Lock
Bed Rails | Full LEDs | Courtesy Lights | Tachometer | Glovebox Lock & Light | Head Light Relays | *Upgraded Fully Super Trim
Rich72C10 is offline   Reply With Quote
Old 04-25-2021, 12:56 PM   #2078
Rich72C10
Mr. Cheyenne
Rich72C10's Avatar
Just replaced my old oil line to gauge, thanks to LockDoc! The old line had like 4ft under the dash. Though I don't think it is any quieter that the old one but it is nice any shinny and nicely looped in the engine bay. Perhaps not professionally looped but it looks a lot better than the old one, that's for sure!
Richard
Old 04-25-2021, 06:22 PM   #2079
FL71C10
Got my cargo light and my cab lights installed.... Baby steps
71 Chevy C10 Shortbed Stepside. LT1 with
4l60E. Just got back from painter, in assembly now.
FL71C10 is offline   Reply With Quote
Old 04-25-2021, 08:27 PM   #2080
67C10Step
67C10Step's Avatar
Pulled my drive shaft to put a new output shaft seal in the transmission. Old seal fought me on the way out but I got it in pieces. Tailshaft had very little play so figur the bushing is not too bad - great. But wait, looks like more gear oil is coming from the speedometer gear housing than the rear seal.
I reached over to give it a wiggle and it came out of the transmission in my hand! The lock plate and screw are gone and have been for quite a while because the bolt hole was completely full of crud. Glad this thing hasn't gone more than about two miles since I got it running.
Should I make myself a lock plate or purchase a new speedo gear housing and all?
1967 C10
1980 Jeep CJ5
2020 Toyota 4Runner
2024 Toyota Tundra
67C10Step is offline   Reply With Quote
Old 04-25-2021, 08:32 PM   #2081
67C10Step
67C10Step's Avatar
1967 C10
1980 Jeep CJ5
2020 Toyota 4Runner
2024 Toyota Tundra
Old 04-25-2021, 09:43 PM   #2082
Steeveedee
Who Changed This?
Steeveedee's Avatar
If the rear seal is shot I'd put the bushing in when I was there. I'd make a lock plate instead of buying the whole magilla, personally.
~Steven
Simi Valley, CA
Old 04-26-2021, 02:54 PM   #2083
72c20customcamper
72c20customcamper's Avatar
Installed the short tilt I purchased from 70shortfleet took about an hour. Nice having the wheel further away and up . Makes getting in and out much easier but I’m a little stumped on the grey wire I’m assuming it’s for the indicator light but I can’t find where it would connect. Mine had the fiber optic wire from the dash bulb
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 04-26-2021, 03:10 PM   #2084
Rich72C10
Mr. Cheyenne
Rich72C10's Avatar
that wire goes to the fuse box, where it powers on when you turn on your lights.
Richard
Old 04-26-2021, 03:50 PM   #2085
67C10Step
67C10Step's Avatar
Can you pull the tailshaft on the transmission without a complete disassembly? If so, I may dig deeper. If not, I may see if this seal will hold for now.
Anybody got dimensions on the speedo gear housing retainer? Doesn't look like something that would be hard to fab up.
1967 C10
1980 Jeep CJ5
2020 Toyota 4Runner
2024 Toyota Tundra
Old 04-26-2021, 04:22 PM   #2086
72c20customcamper
Was looking for a wire under the dash
Found it it's where the light for the cigarette lighter lite is plugged into. For now I put the indicator there and I'll write up a pigtail
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 04-26-2021, 04:36 PM   #2087
OregonNed
OregonNed's Avatar
Went to a large regional truck meet
Yesterday. Won the award for nicest truck bed.
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop
OregonNed is offline   Reply With Quote
Old 04-26-2021, 04:52 PM   #2088
Steeveedee
Who Changed This?
Steeveedee's Avatar
We used to just force them further into the transmission and install the new bushing. True fact.
~Steven
Simi Valley, CA
Old 04-26-2021, 08:18 PM   #2089
toolboxchev
Cool, have not heard about this one locally. What is the name of the event?
toolboxchev is offline   Reply With Quote
Old 04-27-2021, 12:00 AM   #2090
OregonNed
OregonNed's Avatar
This was put together by the Northwest C10 group (can be found on Facebook) and the cruise was in Enumclaw, WA. It is planned to be there again next Spring.
Old 04-30-2021, 05:36 PM   #2091
30772
Painted inside of my 72 K20 cab today.....getting there, slowly but surely!
30772 is offline   Reply With Quote
Old 04-30-2021, 05:52 PM   #2092
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Looks good, I like the color.
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
R.I.P. FleetsidePaul
Old 04-30-2021, 06:01 PM   #2093
30772
Thank you. I wanted to "spark it up" a bit over the original medium blue & white two tone, but keep it "era correct" The color was available in 72 but only on the flashier models - corvette, camaro, chevelle, etc.
Old 04-30-2021, 07:14 PM   #2094
MySons68C20
MySons68C20's Avatar
Lookin good 30772!
MySons68C20 is offline   Reply With Quote
Old 04-30-2021, 11:46 PM   #2095
BC10
BC10's Avatar
Big shout out to Wes Hepp!
For the first time, my heater control is alive!!!
BC10 is offline   Reply With Quote
Old 05-02-2021, 10:43 AM   #2096
Rich72C10
Mr. Cheyenne
Rich72C10's Avatar
At Sunday cars and coffee. Think time I parked next to a C10 lol
Richard
Old 05-02-2021, 12:19 PM   #2097
Rich72C10
Mr. Cheyenne
Rich72C10's Avatar
What else did I do today? I got my email from Quadrajet Power they have started on my rebuild and now have paid for the work! It should be here soon! YAY!!
Hi, we have disassembled and evaluated your 7042208 for your level 2 performance build for you 72 C10. Carb was clean, but had several calibration errors typical from a commercial remanufacturer as they try to make all carbs generic. We will correct the calibration specific for your build and replace all of the serviceable parts.
Richard
Old 05-02-2021, 05:47 PM   #2098
NoStopN
NoStopN's Avatar
This past Tuesday, I pulled the uno barrel carb off my truck to check for a leak. Nothing was wet, but I haven't run it much since November, so everything in the bowl likely leaked out & dried. Found a bolt was missing that held the base part to the midsection. Went on a mad hunt for another screw at every hardware store in town. Had to settle for a bolt. Just got the tags legal on Friday. As long as the weather will cooperate, I'll get the tires dirty tomorrow.
1969 GMC 2500. 250 I6, 4-speed w/ granny low
NoStopN is offline   Reply With Quote
Old 05-03-2021, 01:50 PM   #2099
davischevy
davischevy's Avatar
I picked it up at the detailer. A little before and after.
I hope to get the rockers changed soon and I sure need a nice dark gold tailgate.
other Larry
Build thread, Arkansas K10
https://67-72chevytrucks.com/vboard/...=755797&page=5
The ability to speak several languages is an asset, but the ability to keep your mouth shut in any language is priceless.
davischevy is offline   Reply With Quote
Old 05-03-2021, 08:04 PM   #2100
Hugh in NC
Hugh in NC's Avatar
Just finished under hood refurb and repaint and Vintage Air install. 1970 C10 Short bed Fleetside. 350/th400.
Hugh in NC is offline   Reply With Quote
