07-14-2004, 01:08 AM | #1 |
wheels for K5
will the wheels off of a new chevy truck work on an 85 blazer? I'm pretty sure the bolt pattern for both is 6x5.5 but am not sure if something like backspacing or hubs would be a problem...
Thanks, -Nick
-'02 Chevy Avalanche, 5.3L, 4x4... needing a small lift and bigger tires -'72 Chevy C-10(350, bored 60 over)dual flowmasters, 3 on the tree -'85 K5 Blazer,305 NO MORE...350 is in,2" lift,33" Mickey Thompson Baja Claw Radials -dads '70 burb (red, 5-7 drop, 350...) www.geocities.com/userc10/truckhome.html AIM: Auntjoedadda |
07-14-2004, 01:16 AM | #2 |
nope, won't fit, the newer wheels are hub centric and the hole in the middle is too small.
1985 Scottsdale Shortbed 4x4 Stout 350 with some "upgrades"-700r4-33x12.5" Mud Tires, Warn 8274-50 winch. 2005 Chevrolet Colorado Regular Cab 2wd 4-banger, 5 speed, Street Pack with 3.73 axle. |
07-14-2004, 01:17 AM | #3 |
thanks, so i'm guessing anything past '87 won't fit?
07-14-2004, 01:20 AM | #4 |
yeah, I tried with a wheel off our 97 suburban and they won't even fit on the rear, the holes in the middle would have to be cut out, the lug pattern is the same though. I see some 88 and 89 model truck that still had the old type rally wheels, wonder if they also use the hub centric design?
