Re: His name is "George" 84' C10
Picked up the last big ticket item of the build (Driveshaft). They did a hybrid setup, steel front/ aluminum rear. Got it installed and while I was under there, reworked the fuel delivery lines. Got rid of that weird loop.
No way to remove those restrictive fittings? I've read where those hard/fabbed 90° fittings are the equivalent of adding >10' of additional line per fitting.
I couldn't figure out a way to get the shut off fitting and first filter before the pump while keeping everything low, without all the crazy loops.
Been working on a way to get inner fenders in while keeping it semi stock looking. Going to be a lot of cutting/ metalwork around turbo and back by the firewall, but this is where I have the most fun. So lets cut up some new fenders! Lap welds is where its at with this thin metal. Ended up raising the mounts about 2-1/2".
