Old 05-04-2021, 08:57 PM   #1
71gmcC15
71gmcC15's Avatar
Re: Charcoal cannister, 1983 Silverado
Why even mess with it and delete it. Plug of the vacuum lines and put a filter on the line coming from the tank. and throw it way. That's what I do anyway. Thare not needed unless you have emissions whare your from. Which if you do I'm sorry.
( second times the charm) 71 gmc c15 307 sbc 373 rear gears positrac sm 465 trans. ( not listed on spid but is original )
94 chevy k1500 350 tbi 373 rear gears 4l60e one wheel peel. Gutless
07 gmc sierra classic rcsb 4.3 lt 5 speed w/t
04 chevy Silverado 1500 ext cab 5.3 4l60e.
81 chevy Scottsdale k10 muncie sm465 Np208 10 bolt 8.2 ( Old Green)
71gmcC15 is offline   Reply With Quote
Old 05-04-2021, 10:35 PM   #2
Loco83
Loco83's Avatar
No can do, the Smog NAZIS here go over the engine bay with a fine tooth comb, If you don't pass the visual test it's over let alone having to run the truck on the rollers.
Loco83 is offline   Reply With Quote
Old 05-05-2021, 09:24 AM   #3
SCOTI
SCOTI's Avatar
And there-in lies the stupidity of the whole process. It can barely pass the actual emissions test by less than .05% based on 80's standards & have every little do-dad it's supposed to & they'll approve it.
But... It could actually burn much cleaner on actual emissions (like a newer vehicle) yet be failed because a 'visual' inspection says a specific part is missing. So even though that EGR isn't there any more & it pollutes half as much as the standards require, it's a fail.
You know.... Saving the Planet & all.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 05-10-2021, 11:59 AM   #4
rodstored-72
chevy truck fan
rodstored-72's Avatar
here.. here...
rodstored-72 is offline   Reply With Quote
Old 05-28-2021, 07:01 PM   #5
Loco83
Loco83's Avatar
Well the old girl passed her smog test, gave her a good tune up, cap and rotor, plug wires and plugs. oil change and new air filter, i'm sure the new charcoal canister helped as the old one was full of gas. Good for another 2 yrs.
Old 05-28-2021, 07:52 PM   #6
TKCR
TKCR's Avatar
Congrats on passing the smog test
