Old 05-04-2021, 10:10 PM   #76
skymangs
skymangs's Avatar
Re: My 58 Brookwood
All mocked up after pulling the column and brakes 5 times to ensure everything fit
skymangs is offline   Reply With Quote
Old 05-05-2021, 10:15 PM   #77
skymangs
skymangs's Avatar
Re: My 58 Brookwood
Here’s the lower column bracket we made
Here’s an "in progress pic of the firewall
Old 05-11-2021, 11:36 PM   #78
skymangs
skymangs's Avatar
Re: My 58 Brookwood
Firewall is all finished and we begin final install on the brakes and column tomorrow
Old 05-20-2021, 09:44 PM   #79
skymangs
skymangs's Avatar
Re: My 58 Brookwood
These are the handmade motor Mount Adapters
The motor Mounts and Adapters required Modification
Old 05-21-2021, 08:49 PM   #80
skymangs
skymangs's Avatar
Re: My 58 Brookwood
We Built the motor mounts and test fit the engine today
Old 06-01-2021, 12:36 AM   #81
skymangs
skymangs's Avatar
Re: My 58 Brookwood
Today we put on the collector’s and welded the O2 bungs
We also created a firewall pass through for the Wiring harness.
Old 06-08-2021, 09:37 PM   #82
skymangs
skymangs's Avatar
Re: My 58 Brookwood
The new alternator came in
The new O2's came in
And we finally pulled that lifting plate off and put the Valley cover back on
Old 06-17-2021, 10:23 PM   #83
skymangs
skymangs's Avatar
Re: My 58 Brookwood
Here is that 600hp LS3 nestled in the engine bay!
Here’s a view From the bottom of That 4L80E and how well it Fits.
Old 06-18-2021, 08:09 AM   #84
gigamanx
Re: My 58 Brookwood
Looking awesome. I like those valve covers on the LS3. A bit of old school flare with the fins. Where did you find them? Is the harness a holley terminator?
Current Build Thread 1930 Ford Model A Modern Twist: Ford Model A Rat Rod With a Modern Twist
Build Thread Phase 1 "The Swap": 1949 3100 with S10 swap. Beginner build with ambition!
Build Thread Phase 2 "The Drop": Beginner Build with Ambition gets Air Ride
gigamanx is offline   Reply With Quote
Old 06-18-2021, 08:14 AM   #85
skymangs
skymangs's Avatar
Re: My 58 Brookwood
Nope, bought it one eBay. $450
Old 06-22-2021, 08:23 PM   #86
skymangs
skymangs's Avatar
Re: My 58 Brookwood
we put 2 3/8 nipples in the bottom for the brake booster and the PCV
Old 06-22-2021, 08:27 PM   #87
skymangs
skymangs's Avatar
Re: My 58 Brookwood
Here’s the overview of how the engine looks in the bay
so we cut the tunnel 7” wide to facilitate the installation of our 12” Lokar tail shaft mounted shifter
Old 06-23-2021, 10:09 PM   #88
skymangs
skymangs's Avatar
Re: My 58 Brookwood
We got the right MAP sensor in today and mounted it
I think it looks clean on the back of the intake
Here’s that LS3 in the engine bay. Just can’t get enough of that sick looking MF'er!
Old 06-24-2021, 07:44 PM   #89
skymangs
skymangs's Avatar
Re: My 58 Brookwood
We put the 3/8 hoses on the intake
Routed the steam tubes
This is the engine with all the Wiring ran and plugged in
Old 06-24-2021, 09:08 PM   #90
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Re: My 58 Brookwood
Looking good!
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
R.I.P. FleetsidePaul
Old 06-25-2021, 09:11 PM   #91
skymangs
skymangs's Avatar
Re: My 58 Brookwood
Thank you
Today we modified the Transmission crossmember to slide 8” back for our 4L80E
Old 06-25-2021, 09:22 PM   #92
Ol Blue K20
Re: My 58 Brookwood
It's coming along nicely. Keep plugging away!
Dale
Old 06-25-2021, 11:36 PM   #93
skymangs
skymangs's Avatar
Re: My 58 Brookwood
We are only able to work on it about an hour a day.
