Old 11-21-2020, 08:53 AM   #226
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: My caster mod (with pictures)
Nice work. I like the bump stops. What are they off of?
Check out this page - https://www.suspension.com/universal-bump-stops.asp
Old 11-21-2020, 11:54 AM   #227
HO455
HO455's Avatar
Thank you.
RIP Bob Parks.
Old 05-05-2021, 11:27 AM   #228
cab4word67
cab4word67's Avatar
Thanks everyone for all these reply's and the great write up. I am starting my 67 drop and want to keep my stock spindles due to a disc conversion and this will be great. Does anyone know what the aliening specs are to be after this mod?
cab4word67 is offline   Reply With Quote
Old 05-05-2021, 04:52 PM   #229
SCOTI
SCOTI's Avatar
Alignment specs will vary depending on the type of build & parts used. Some guys won't stray from OE specs.
OE called for Zero to POS .5 Camber. I target NEG .5 Camber.
For caster, I request as much as possible w/o impacting my Camber target. These C10's didn't have much Caster to begin with. If you can get 5° that's pretty decent (I was able to yield 6.9/7.4 for reference).
Toe was pretty close to OE. The larger/wider the foot-print, there might be need to adjust to account for the increased contact patch.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 05-05-2021, 08:58 PM   #230
cab4word67
cab4word67's Avatar
Thanks pretty much what I did on my 65 Mustang
Old 05-18-2021, 11:10 AM   #231
HO455
HO455's Avatar
I posted my alignment specifications on post 214.
RIP Bob Parks.
Old 04-15-2022, 01:26 PM   #232
67LS3GMC
I know this is an old thread but I did this mod to my 67 and I have severe tire scrub when I turn, is it normal ?
67LS3GMC is offline   Reply With Quote
Old 04-15-2022, 02:21 PM   #233
SCOTI
SCOTI's Avatar
After re-aligning?
What are the final alignment specs?
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 04-15-2022, 04:06 PM   #234
67LS3GMC
Not sure on caster need to find a shop I trust. Set at home Toe is 1/8" camber is close to 0. Drives good just when I back out of a parking spot and turn the wheels hard one of them will scrub bad (as in tear up grass or leave a black mark) they have a different turning radius from each other ?
Old 04-15-2022, 04:59 PM   #235
SCOTI
SCOTI's Avatar
You'll def need to get it dialed in after the mod since it's a significant change. With the Caster Mod, guys are usually seeing around/over +5°. These trucks were lucky to ever see +3°.
I have 6.9/7.4 on my dually. Going from reverse to forward there is a shift but once you're moving it's not an issue. Toe needs to be dialed in as well.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 04-15-2022, 06:18 PM   #236
HO455
HO455's Avatar
Not normal! I did it on my 67 with no issues.
As previously recommended get thy truck to the alignment shop.
Now it is possible to install the upper control arms on the wrong sides and to put the centerlink on backwards. I have no idea how much of the front suspension you worked on but these are easy things to check before going to the alignment shop and trust me they are much cheaper to rectify at home, rather than when your truck is up on the rack.
Good luck and please share your findings.
RIP Bob Parks.
Old 04-15-2022, 07:27 PM   #237
67LS3GMC
It was frame up build, all new components. 2" or 2-1/2 spindles (don't remember) 1" springs etc.
Old 04-15-2022, 09:31 PM   #238
SCOTI
SCOTI's Avatar
Ahhh.... Definitely verify the a-arms are on the correct sides & the Center-Link isn't backwards. I bet you're ok on the Center-Link because there's typically tie-rod to x-member interference when that occurs.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 04-16-2022, 01:12 AM   #239
cab4word67
cab4word67's Avatar
how does one know if the upper control arms are backwards?
Old 04-16-2022, 10:32 AM   #240
cwcarpenter98
cwcarpenter98's Avatar
Yeah, don't be like me and try to get it aligned with the UCAs on backwards. It won't work well.
Fist picture shows them on backwards. See how there's more angle between the UCA and the top of the spindle?
Second picture shows them on the correct side. Look at how the UCA and top of the spindle are sitting more parallel.
You want to have the bump stop towards the rear of the truck.
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 350, Saginaw 4 speed
Old 04-16-2022, 10:45 AM   #241
cab4word67
cab4word67's Avatar
Yes I see, the spindle is more in line with the front UCA mounting bolt too.
Old 04-16-2022, 12:39 PM   #242
67LS3GMC
Yes A-arms on correct side, as my helper double checked all my work on the truck.
http://www.67-72chevytrucks.com/vboa...1&d=1650127136
Old 12-29-2022, 08:43 AM   #243
dhigdon@southerntank
So if I use tubular control arms for my 67 build I will not have this caster issue, is that correct?
dhigdon@southerntank is offline   Reply With Quote
Old 12-29-2022, 09:27 AM   #244
SCOTI
SCOTI's Avatar
Depends on the arms.
Some tubular arms are nothing more than a copy of the OE stamped steel arm while others might refine some of the geometry by making changes.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 07-20-2025, 01:10 PM   #245
HO455
HO455's Avatar
This thread should be a Sticky!
RIP Bob Parks.
