Old 05-08-2021, 08:05 PM   #2
Pontiac1976
Pontiac1976's Avatar
Re: Rear Sliding Window Chrome Clips
Try Classic Parts Link: https://www.classicparts.com/frame-truck-years.html
Maybe LMC those com to mind first
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed
Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change.
Pontiac1976 is offline   Reply With Quote
