Fuel problems
I have a 85 305 in my 65 Chevy. I have had issues with fuel pumps the last few years. I put a clear inline filter on it and with the engine running it only has a small amount of gas in it . Should the pump keep the filter full? I have considered using an electric pump. Anyone have any suggestions?Thanks.....R C.
Moderator
![]() ![]() Join Date: Aug 2011
Re: Fuel problems
I've not seen a full clear fuel filter in the past.
Re: Fuel problems
Me neither, usually half full. Remember that any pinholes on the suction side of the line will allow air bubbles to enter the fuel stream. Since those leaks don't get pressure they are harder to spot. Also, the pick up tubee in the tank has a screen on it. I have had a nasty one restrict the fuel draw of the pump enough to starve the motor before. As for an electric pump....I'd prefer a good solid mechanical set up.
Re: Fuel problems
Thanks for the replies. When it is running at idle there is a very small amount of gas in the filter. I was talking to a friend at work today and he also said it could be a problem with the suction line. I checked the screen in the tank and it was ok. I'll try to check the line this weekend. At highway speeds it sometimes acts like it is running out of gas but when I slow down it is fine. I would like to stay with the mechanical pump if I can.
Who Changed This?
![]() Join Date: Jan 2013
Re: Fuel problems
I had a '66 Le Mans with a 400 (not original) Ram Air III that had one of those glass filters that never seemed to be full of gas. It turned mid-13s in the quarter mile though, so I quit worrying about the glass not being full. I'd recommend going through the fuel system and eliminating potential problems like pinhole leaks and clogged socks, just to cover all the bases, though.
#6 | |
Re: Fuel problems
My truck ain't dead, it just smells funny. |
Re: Fuel problems
Have you checked or rebuilt the carb lately. Incorrect float levels, or a piece "trash" blocking/clogging a main jet.
If your truck runs hot, it could be a minor vapor lock issue. Once the filter element gets saturated with fuel, it may be trapping some air. Try back filling/purging the filter or carb line. |
Re: Fuel problems
My '77 C10 got all new lines, tanks, pump, filters, the works, when I put it all together years ago. I went through three brand new Carter mechanical pumps, and the filter always seems marginal, but I also was starving the carb of fuel in traffic - it just wasn't getting fuel.
I re-routed lines, I put heat-wrap on the fuel lines around the motor and headers, I put the filter after the pump instead of before, but nothing improved it - except switching to an electric pump which has been the best thing ever. I am running an AC Delco EP12S.
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, turbo, LS 1977 Silverado: Shortboxed & dropped, potato-potato V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag Lotus Super 7 Replica: Scratch-built street-legal rollerskate |
Re: Fuel problems
SkinnyG, did your take the mechanical pump off or or leave it on?
Re: Fuel problems
I took it off, and removed the rod as well. I purchased a cheap chrome blanking plate for the block.
It's also easy to wire a switch to disable the pump for parking in shady areas. Thief can drive as far as a float bowl will allow.
Re: Fuel problems
The ability to switch off the pump is something I like. I have a hidden switch on the hot wire for the distributor already. Another theft deterrent is always a good idea. I didn't get time to work on it this weekend, life keeps getting in the way.
