Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Info Center > Review Board > Vendor Reviews
Old 05-09-2021, 08:45 PM   #1
Slowguy
Lmc front 67 grill trim is terrible! Anyone else have this issue?
I ordered the front upper and lower aluminum trims from lmc and I’ve spent hours trying to make it work. I thought it was the clips but then I put one in my old trim and it popped right in. I think they squeezed the little channel the clips into, too tight and it’s not wide enough to allow the clips in? Any suggestions or maybe a better quality supplier for these?
Slowguy is offline   Reply With Quote
Old 05-09-2021, 10:28 PM   #2
Accelo
Accelo's Avatar
Re: Lmc front 67 grill trim is terrible! Anyone else have this issue?
I fought the tail light trim like you are, they are similar so I am posting what worked for me.
On my first try I pushed too hard and damaged the aluminum bezel. However, after purchasing a replacement bezel I managed to get it to work. First, can you go up a 1/64 on drill size of the holes? Something to consider but may not be mandatory. They be sure the holes are debured on both sides. Typical takes a deburing tool like the one in the picture. Then paint the bare metal if you have any. I used a pliers to collapse the clip as much as I could and retain some shape. Then brush on a little grease on the clips. This worked for me. The reproduction clips are crap in my opinion but it's what we have to work with.
Best of luck.
Rick
Accelo is offline   Reply With Quote
Old 05-10-2021, 02:19 AM   #3
franken
Sorry for the trouble, but it's important to understand that LMC sells stuff, they don't make anything. Another vendor likely as not sells the same thing, from the same maker.
franken is online now   Reply With Quote
Old 05-10-2021, 03:54 AM   #4
1970cstblazer
1970cstblazer's Avatar
File or grind the clip just enough to fit?
1970 K/5 Blazer CST 4WD, TOTM winner December 2024! Medium Bronze poly, 93k ACT. miles, 350, 4 speed, rear positraction, 16.5" x 8.25" HD Kelsey Hayes wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration finally getting close to completion..
2017 Sierra 1500 SLT 4WD, Black, 46k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2...
2019 Canyon SLT 4WD, White, 67k miles, 3.6, 8L45, 3.23 LS, 18" wheels
Old 05-10-2021, 07:44 AM   #5
Slowguy
First, I thought this might come up, but I'm not knocking LMC in anyway. They have more stuff for sale than any other vendor for these trucks. I am, however, knocking the quality of these trims/clips. I have a lot to restore on this truck and the last thing I have time for is to spend hours on is getting these silly little clips to fit in the channels with the trim they were supposedly designed for. I was asking if anyone had any other alternatives to the brand that LMC sells. I was really surprised to see the quality vs the price they charge for 10 cents of thin aluminum and poorly made clips. I get frustrated with many things along the way as it becomes tedious, but this one is up there.
Old 05-10-2021, 10:30 PM   #6
Getter-Done
Getter-Done's Avatar
Slowguy
This is why I Love this forum soo much.
You are able to ask (Has This Happen to You)
In time you learn a-lot of info you get.
And who is giving the Info.
This Needs to be sifted thru .
That is why I Wish GMC Pauls was close.
They are Well Known for not selling Inferior Products.
(By the way I am not a Paid Sponser)
I posted a Link just a few days ago about the (This) trim from another Vendor.
I was Not aware that it was Aluminum trim.
I did not get offended by this
This is a Live/Buy/learn/ and please share forum.
Share knowledge and past experience.
I hope you get your grill trim Just like you want it.
The early bird gets the worm,
84 Chevy K-20
Old 05-10-2021, 11:24 PM   #7
Smitty
Smitty's Avatar
Google YoPeCo products and see if you can locate their online catalog. Or someone in your area the reps for them. We have such a place near me so I don't have to buy fasteners by the box. They handle a lot of the oem type fasteners.
Smitty
'71 Short Fleetside
Spring Valley, Ca.
Smitty is offline   Reply With Quote
Old 05-11-2021, 05:33 AM   #8
Grumpy old man
Grumpy old man's Avatar
Are these the trim clips you are using to install the grill trim hoops. ?
https://www.ebay.com/p/24018769431?iid=274613752469
Old 05-11-2021, 09:17 PM   #9
Slowguy
No. The ones I used came with the lmc trim as a set. These are black and have two wire springs per clip.
Old 05-28-2021, 11:26 AM   #10
Tim Christian
Tim Christian's Avatar
I don't mean this bad but everybody says the same thing you do but I install them all the time with out issue a lot of it is experience. Yes they probably could be made better but they will work with patience. Just my experience.
Tim Christian is offline   Reply With Quote
Old 05-28-2021, 11:31 AM   #11
Slowguy
Oh, I agree. I'm sure they will install with enough patience. I just don't think I have that much patience when I realized the clips would install in the original trim within seconds and I spent an hour messing with the new trim to try and get two clips to stay in place. I quickly decided I'd rather spend that time getting the braking system operation rather than messing with the trim.
