Old 05-14-2021, 08:40 AM   #1
maverickmk
WTB Fuel Sending Unit
I have purchased 2 fuel sending units from 2 different vendors and both of the floats are filling up with fuel. Does anyone have sending unit for the in-cab tank with at least a good float? If all else fails I may try to pull the one I have and see if I can get it to dry out and then use that spray flex seal stuff
*Edit: I have an I6 - 250*
maverickmk is offline   Reply With Quote
Old 05-14-2021, 08:56 AM   #2
Ironhorse
Ironhorse's Avatar
Re: WTB Fuel Sending Unit
I have a good working fuel sending unit pulled from a '70 3/4 ton with 350 V8. Not sure it has the float with it tho. Will check the parts stash later today and get back with you.
1971 Chevy 1/2T 4x4 LWB 350 V-8
Was sm465-now 350TH/np205
Tilt, Tach, Towhooks
Original Truck AM/FM
Wellington, Ks
Ironhorse is offline   Reply With Quote
Old 05-14-2021, 09:15 AM   #3
maverickmk
Thanks, I appreciate it.
Not sure if it matters, but I have an I6 - 250.
Old 05-14-2021, 10:14 AM   #4
chevmn
Had same issue couple years ago, and apparently this is very common. I ended up finding a plastic (not sure of material) float on ebay which snap right in, and still working. Seems like it was only about $5 or so. Just another option for those who might see this and having same issue. If I recall it was being sold for a Jeep of some sort that used similar float
edit: I believe this is the item
https://www.summitracing.com/parts/o...RoC83QQAvD_BwE
chevmn is offline   Reply With Quote
Old 05-14-2021, 11:05 AM   #5
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
I'm using that plastic one too. It's working great!
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
R.I.P. FleetsidePaul
Old 05-14-2021, 12:53 PM   #6
Ironhorse
Ironhorse's Avatar
Didn't find the sending unit from the '70 3/4 ton with the 350 V8. I do have a sending unit from a 67 GMC with a non-running in-line six. It looks good, moves freely on the float arm, still has the brass float and sock altho it is discolored with age.
Is there any way to test a sending unit out of the stock tank laying on the work bench?
Never have tried doing that before, no idea how. I do have a multi-meter but not sure how to attach the leads for a correct reading.
Wellington, Ks
Old 05-14-2021, 01:01 PM   #7
maverickmk
I appreciate it, but I just ordered one of those floats from Summit. I'll give that a shot and see how it goes.
Old 05-14-2021, 01:38 PM   #8
chevmn
I have seen a lot of posts on the Internet regarding this issue with the replacement sending units, and many suggest to retain the old floats from bad sending units, or purchase one of the plastic ones as described. Which reminds me, I am putting a truck together and have a new sending unit. This float actually looks decent, but I am tempted to either submerge it and see how it does or just replace it before I even put it in the tank. The other one I had issues with was very obvious it appeared to have several cracks in it, so no way it would ever work.
Old 05-14-2021, 05:41 PM   #9
RenoKeene
Florida Edition
RenoKeene's Avatar
I've had the same problem with aftermarket floats. Seems maybe the crap fuel they sell us in conjunction with cheap metal might have something to do with it. I'm running OEM right now but plastic might be the answer (if the crap fuel doesn't eat them too).
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod
67 C-20 Slant Back Wrecker "Mad Max"
67 C-10 Ratrod "Step-N-Wolf"
71 Serro Scotty Sportsman camper "Scotty"
97 LT1 Z28 "The Hornet"
Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684
Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394
RenoKeene is offline   Reply With Quote
Old 05-14-2021, 06:05 PM   #10
Ironhorse
Ironhorse's Avatar
Posted a question about checking the sending unit and the way I was doing it is correct. Looks like the sender is fried. Will keep the brass float and the locking ring, scrap the rest. Glad you found what you needed.
Did find a second sending unit and tested it as I was instructed via another thread. It tested good with the ohms changing with range of motion on the float arm. Only issue is looks as if the flare nut fitting was cut off at some point and guess maybe they used a rubber line and hose clamp. Works but not per the General when built. But then a lot of things on these trucks get changed thru the years.
Glad you got your float ordered. If it turn sour for you let me know as I do have an original brass float that needs a home, LOL.
Wellington, Ks
