Anybody know how high the rockers are welded into door jamb on 1967-1972 Chevy
I purchased some new sheet metal for both sides of my 1968 Chevy C10 which includes rockers, inner rockers then front and rear cab supports.
When I get to the rockers what does the factory installation of a rocker panel look like on a 1968 Chevy C10. I am not exactly sure if my factory rockers have been messed with already and want to see other examples of the door jamb area where the top of the rockers are. |
All about them K’s
![]() Join Date: Jun 2014
Re: Anybody know how high the rockers are welded into door jamb on 1967-1972 Chevy
You really can’t accurately go about it this way. The best thing to do is keep the doors on it and when you hang the new outer rocker, mount it so that it gives you a good gap between the door and rocker at the bottom and nothing rubs anywhere while opening and closing the door. Use sheet metal screws to hold it in place while you adjust it around and get it fitting good. You may have to make pie cuts in a few places or otherwise modify it some to get it fitting right.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 ![]() |
#3 | |
![]() Join Date: Feb 2009
Look for small indentations at the edges of the rockers. Like little dimples. The factory uses a spot weld that leaves the little dimple. They should be 3-4” apart at all the edges
![]() Join Date: Aug 2015
might be what you're looking for,2nd picture flipped sideways, obviously it looks better now, lol good luck
A Little Better Every Day Cancer Survivor, most dont know what they have until its gone, appreciate everything |
