Old 05-16-2021, 09:21 PM   #1
72Mountaineer
72Mountaineer's Avatar
Re: Problem with Neutral Safety Switch Continuity - Help!
Take out the NSS from the shifter, then you'll figure it out. They'll be a "button" on the switch (or on the shifter) that depresses (or doesn't) when in gear (or not in gear). I know this sounds confusing, but take it apart and you'll find your answer.
72Mountaineer is offline   Reply With Quote
Old 05-16-2021, 09:32 PM   #2
NeoJuice
The NSS has a ball bearing on the bottom of it and it gets pressed in/out as you move it from gear to gear.
NeoJuice is offline   Reply With Quote
