Old 05-18-2021, 01:57 AM   #1
AllGoNoShow
Dropping front crossmember as one piece?
So I was going to paint the front half of the frame while I was swapping engines and was originally just going to work around the crossmember (which someone previously painted). Just looking at it now, though, is it possible to drop the crossmember with the control arms, springs, wheels and everything in place? Looks like it’s just 6 bolts holding it to the frame and then detach the shocks and brake lines? Would removing it and putting it back in even necessitate a front end alignment? Was just hoping to be able to wheel it out from underneath as one piece.
AllGoNoShow is offline   Reply With Quote
Old 05-18-2021, 02:08 AM   #2
bagged68chevy
bagged68chevy's Avatar
Re: Dropping front crossmember as one piece?
Yes you can unbolt it and roll it out. Shouldn’t need re aligned.
bagged68chevy is offline   Reply With Quote
Old 05-18-2021, 02:14 AM   #3
67 twins
Location: Herculaneum MO (20 minutes south of St. Louis
It's a total of 10 bolts
67 C10 283 T5 swapped longbed fleetside = wife's daily driver
67 C20 292 (originally a 250)4speed longbed fleetside w/original wooden bed=my project truck
67 C10 283+.060 (so a 292 as well)T5 swapped longbed fleetside=my DD
72 C1500 Sierra Grande 350 TH350 longbed fleetside=wife's fair weather truck
Can you tell we are fans of longbed fleetsides & 67s
Chris
67 twins is offline   Reply With Quote
Old 05-20-2021, 11:27 AM   #4
dmack91
dmack91's Avatar
I am in the middle of swapping an 84c10 front cradle into my 70c20. There are 4 bolts going through the side of the frame and 3 through the bottom on each side. Plus, you will have to pull the motor mount plates as they bridge from the cradle to the frame.
68 Chev C20- son has it now
83 K20 - bought from son
70 C20 - in progress
dmack91 is offline   Reply With Quote
Old 05-24-2021, 07:20 PM   #5
57larry
yes it can be done
57larry is offline   Reply With Quote
Old 05-24-2021, 08:57 PM   #6
lousyflyer
Well, its cumbersome and heavy. Items recommended but not required:
2 strong friends - One to help, one to step in when the first guy gives up.
Some type of penetrating oil - the bolts are always crusty.
Air or electric impact - those crusty bolts seem REALLY long after the first two or three.
Beverages
Last but not least - safety glasses
They tell me that I have Bipolar disorder.
That doesn't really bother me.
30 minutes from now it might, but not right now.
lousyflyer is offline   Reply With Quote
