![]() Join Date: Aug 2014
292 Help
I bought a truck a few years ago with what I was told was a totally rebuilt 292 block installed. But it was rebuilt 30 years ago. It has been painted and taped over all the holes. The truck came with a box of parts but very few engine parts. I think I have an intake manifold and an exhaust manifold and perhaps a correct pulley but that is all. Any suggestions for what this engine is supposed to look like and where is a good place to be buying all the needed 292 parts for it. For example there is no carb or distributor, etc. I think I may be able to find an old 292 in a local truck sitting in a field locally, but that is now my only source of info other than looking at photos on this site.
1972 Chevy Custom Deluxe Highlander, owned 34 years. 1970 GMC Sierra Grande 2500, unrestored, original. 1970 Chevy K10 Short Wide-bed, working on restoration.. 1967 Chevy K10 Short Stepside, unrestored original. 1969 GMC CST (Longhorn) 396, buckets, unrestored. 1995 GMC K2500, 65,000 miles, 454. |
Re: 292 Help
There are many older posts on the forum that will have info and pictures that will help you. There are some parts that also fit the 250 inline, such as the distributor. Points distributor and '75-up HEI. Some aftermarket parts for the 250/292 such as HEI, Aluminum intake, tube headers are available.
292 water pump and by-pass hose are available from your FLAPS, but the 292 thermostat housing will have to be sourced used from who knows where. This thread is one of many you will find to get you going. https://67-72chevytrucks.com/vboard/...292+water+pump
'67 GMC 2500, 292, 4spd, AC |
![]() Join Date: Dec 2013
Re: 292 Help
I should have all the parts you need , Make a list and let me know what it is . I have 1 -292 out of 67 model truck and another later model , some extra parts , dist , carb , oil pan ,alt , brackets , fans , radiator , fan guards , etc
![]() I'm getting ready to sell off some 67 trucks / parts trucks , Tn Titled in my name long bed / short bed frames / with vin matching cabs Also clutch linkage , 3ott steering columns
![]() 1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop Last edited by Grumpy old man; 05-19-2021 at 04:41 PM. |
Re: 292 Help
The carb. from a 250 will fit but has smaller pasagways. You will leave power on the table. A 292 carb is hard to find as the reman places mix them all up. The manifolds will work OK .
George |
#5 | |
Re: 292 Help
Re: 292 Help
Thanks Richard. I enjoyed the reading. I have a lot to learn. I have never owned a 292 before.
Re: 292 Help
I don't want to turn this into a for sale thread , I'll send you a PM and if your interested I'll list it on the parts board .
![]() 1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
Re: 292 Help
Hello Grumpy, I just went through the bins that came with this truck and found this part that looks like the base for a thermostat, but it does not look like any of the ones you posted on a previous thread about 292 engines. Can you help me identify this? There is even a part number on it. It looks like 3789160. I too would be interested in parts you have for sale for this engine. Thanks, george
Re: 292 Help
More photos of part.
Re: 292 Help
That part # comes back to a 1963-1965 Chevy Impala 230 6 cyl Lower Thermostat Housing OEM 3789160 It seems there are multiple applications .
https://southeastchevyparts-com.3dca...60_p_2385.html https://picclick.com/1960s-Genuine-T...023513030.html 1960s Genuine Truck GMC GM Lower Thermostat Housing Rare Old Part 3789160 Rare
![]() 1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop Last edited by Grumpy old man; 05-20-2021 at 11:14 AM. |
Re: 292 Help
I'll take some more pictures and part #'s today . and post them up later today .
![]() So many of the 6 cyl engines from our trucks have been pulled and scraped it's getting harder to find these parts .
#12 | |
Re: 292 Help
Re: 292 Help
Just for general info , I've had good luck chasing unknown part #'s by searching like this typing capital GM part # seems to yield good results .
GM 3789160
Re: 292 Help
Thanks for the tip!
#15 |
Re: 292 Help
#16 |
Re: 292 Help
I rebuilt a 292 and dropped it into a GMC 1500 . Boy what a stump puller. It ate engine mounts from all the torque. Lots of fun at shows compared to all the V8’s...good luck.with your build..Jack
71 C-20 07 Magnum RT AWD |
#17 |
![]() Join Date: Feb 2002
Re: 292 Help
If you have a legible SPID on the glovebox door, the RPO code ''L25'' means a 292 L6 option.
| Bookmarks |
