Old 05-25-2021, 05:41 PM   #26
54blackhornet
54blackhornet's Avatar
Re: Converting 2WD Heat Stove to 4WD
Question ? I tried to remove the heat stove from my 307. Got the small sheet metal screws loose but no luck with the nut down low ? It’s never been off ever ? Been soaking it with PB but still stuck tightly.
71 C-20
07 Magnum RT AWD
54blackhornet is offline   Reply With Quote
Old 05-25-2021, 06:03 PM   #27
davischevy
davischevy's Avatar
Put some heat on the nut. It will expand and break loose.
other Larry
Build thread, Arkansas K10
https://67-72chevytrucks.com/vboard/...=755797&page=5
The ability to speak several languages is an asset, but the ability to keep your mouth shut in any language is priceless.
davischevy is offline   Reply With Quote
Old 01-28-2024, 03:12 AM   #28
cericd
cericd's Avatar
Thought I'd add these pics I found online of a NOS heat stove P/N 3982954 which is also finished in black.
Chris
My 1970 SWB C/10 - https://67-72chevytrucks.com/vboard/...d.php?t=534872
cericd is offline   Reply With Quote
Old 01-28-2024, 09:28 AM   #29
IronCanine
IronCanine's Avatar
What a great pic. Thanks Chris.
IronCanine is offline   Reply With Quote
Old 01-29-2024, 02:55 PM   #30
1970cstblazer
1970cstblazer's Avatar
Lightbulb Re: Converting 2WD Heat Stove to 4WD
Thank you for the pic. That's the way I restored mine, with the satin black outer and bright plated inner. I was going by the very low mile 1970 that has been pictured here in the past.
Old 01-30-2024, 02:21 PM   #31
54blackhornet
I noticed in a few photos the flexible oil dipstick ? The one in my pretty original 71 307 with power brakes has it sticking straight up ? Also has the oil fill pipe , you have to be Houdini to get it out, nearly impossible to reinsert.
71 C-20
07 Magnum RT AWD
4x4, exhaust manifold, heat stove, riser
