Old 05-07-2019, 10:39 PM   #1
Sspirawk
12 bolt help
Anybody have a tip or trick for not over tightening the crush sleeve
Scott
Sspirawk is offline   Reply With Quote
Old 05-08-2019, 07:40 AM   #2
Mike C
Mike C's Avatar
Re: 12 bolt help
Are you assembling with a new sleeve or are you just replacing a pinion seal and re-tightening?
My experience is it takes a 4’ cheater bar to crush a new sleeve and something equal to hold the yoke if assembling a diff. I use my IR 1/2” impact to crush new ones usually. Sometimes the hammering doesn’t work as it just loads and unloads but doesn’t crush the sleeve. That’s when a cheater comes in.
When replacing a pinion seal I use a 1/2” ratchet and just get it as tight as I can. I’ve never seen it add to crush.
If you are doing the latter, I recommend a new pinion nut.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 05-08-2019, 02:21 PM   #3
Sspirawk
Re: 12 bolt help
Complete rebuild, new everything 3.73 plus a posi unit.. thanks for the help
Old 05-08-2019, 03:16 PM   #4
Indychus
Indychus's Avatar
Re: 12 bolt help
I do the same as Mike C... run it in with a 1/2" impact. I stop frequently and check the preload until it gets exactly where I want it. It takes somewhere around 3-400 ft lbs to even start to crush one, so I've never had an issue with over crushing one as long as I check the preload frequently as I'm tightening it up.
Build Thread: Project Overkill 1968
Bagged & Blown Pro Street 1968 Short Fleet
Indychus is offline   Reply With Quote
Old 05-08-2019, 08:42 PM   #5
firedemon
Re: 12 bolt help
I just did mine I did it in the truck used a big pipe wrench to hold the yoke it was long enough to go over to the trailing arm . then used a half inch rachet with a piece of pipe to make the handle longer and just kept tightening it till it didn't rock in the races anymore . when it started getting close I kept an eye on the socket so I didn't turn any more than an 1/8 inch at a time till it got the right rotational torque . was way easier than I thought
firedemon is offline   Reply With Quote
Old 05-08-2019, 10:59 PM   #6
Sspirawk
Re: 12 bolt help
Sounds good guys. L
I'll probably shortcut it and pre crush it on a press at work, figure I'll get to .030 of the original and the finish it in the rear end
Old 05-26-2021, 09:55 PM   #7
Romo912
Re: 12 bolt help
My pinion bearings under preload are not smooth. Is this normal? Thanks
Romo912 is offline   Reply With Quote
Old 05-27-2021, 01:55 AM   #8
Accelo
Accelo's Avatar
Re: 12 bolt help
I have personally had no luck with impacts. When you are close there just isn't the control you need when using an impact. I can almost guarantee you will end up over tightening the pinion and your preload will be too high.
I use an extra long SnapOn breaker bar with a cheater on it.
I back up the pinion with a pinion wrench but there is no reason a large pipe wrench wouldn't work. I just can't have teeth marks on customers pinion yolks. Adapting a typical 1-5/16 socket to a 1/4" square drive inch pound torque wrench is always and issue. Preplan for this or you will end up guessing on the torque.
Can be but, but guessing by your description the nut may be over tightened? What is the turning torque when this is an issue?
Typically you have a brake away torque and turning torque. This is why you need to use a dial type torque wrench for this job.
Rick
Accelo is offline   Reply With Quote
Old 05-27-2021, 08:16 AM   #9
Bigdav160
Bigdav160's Avatar
Re: 12 bolt help
Probably. Well lubed and broke in they'll be smooth
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 05-27-2021, 10:32 AM   #10
71meangreenc10
Its a Truck Thing......
71meangreenc10's Avatar
Re: 12 bolt help
Go get a inch pound torque wrench and don't guess.
You will be surprised how much crush is needed to get you into spec.
Do not Pre-Crush the sleeve. If you cannot get the resources to set it up right, then find someone who does.
This is an area that you do not want to guess. I have seen it, you don't want to experience it. You put too much money into it to not finish it correctly.
Smitty
71 C10 283/3SPD Full Resto
71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599
70 C10 Suburban Former military GSA truck.
72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378
72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110
68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head
71 C30 Wrecker
71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck
68 GMC Long Stepside. They keep following me home
69 C30 Former Motor Home, Flat Bed time
70 G20 Red-E-Kamp Conversion "I'm your Boogy Van"
71meangreenc10 is offline   Reply With Quote
Old 05-27-2021, 10:36 AM   #11
71meangreenc10
Re: 12 bolt help
New bearings installed correctly under preload will not turn smooth. They are supposed to have a drag.
Smitty
71 C30 Wrecker
Old 05-27-2021, 01:21 PM   #12
Accelo
Accelo's Avatar
Re: 12 bolt help
The turning torque required should be fairly smooth. One can see this on the torque wrench needle as it's rotated. In my experience if torque needed to rotate the pinion raises and drops significantly, after the pinion is turning, the preload is too high. But you are the judge on that, I am not on site.
Old 05-28-2021, 07:48 AM   #13
CUSTOM/10
CUSTOM/10's Avatar
Re: 12 bolt help
Go to posting numbers 558 to 574, in the link below. It shows how I did it utilizing a jack to slowly crush the sleeve. Starting on page 23 I believe.
Gary
http://67-72chevytrucks.com/vboard/s...d.php?t=259859
Gary
72 SWB 4x4
My 72 SWB Build
CUSTOM/10 is offline   Reply With Quote
Old 05-28-2021, 04:45 PM   #14
71cadc10
71cadc10's Avatar
Re: 12 bolt help
if the sleeve is a lot longer than the original, i would not 'pre-crush it'. The bulged part of the sleeve really only works like a spring for so many thousandths of an inch...then it humps up in the middle and won't act like a spring any more. If that makes sense.
if it's too long, then I'd grind off some material squarely from the ends. Keep the bulge part in the center in tact for when you crush it down. The crush sleeve has a working range basically...you can tell if you crush past that point as it will get a LOT easier to turn the breaker bar
71 C10 long bed, 2003 6.0L, 06GTO E40, T56, 12bolt 4.10 rear
71cadc10 is offline   Reply With Quote
Old 05-28-2021, 05:16 PM   #15
gmc684x4
Re: 12 bolt help
You could use a 12 bolt crush sleeve eliminator
Here is one from Dennys for example
https://www.dennysdriveshaft.com/p87...olt_truck.html
gmc684x4 is offline   Reply With Quote
Old 05-29-2021, 01:50 PM   #16
Accelo
Accelo's Avatar
Re: 12 bolt help
The crush sleeve eliminators are a good idea. They allow you to tighten the nut enough to add some additional axial force to assist in retaining the bearing during high loads. The disadvantage is getting the preload correct requires removing the bearing, possible more than once. If I was going to use crush sleeve eliminator I would install the crush sleeve to get my preload and then measure the length of the sleeve. Then use the measurement as a starting point on my shim stack. Of course this would eliminate any assembly advantage of the shim stack.
Setting up your first differential is a daunting task for the newbie.
When working on your differential you will need a wide variety of tools. Using the correct tools saves time and helps prevent parts from being damaged. Here is a list of some of the tools that you may find handy:
Dial indicator
Gear marking compound and a brush
Calipers or a micrometer (to measure shims)
Bearing pullers
Bearing press
Three foot long breaker bar or strong impact gun
Pinion nut socket (often 1-5/16")
Ring gear bolt socket
Carrier cap bolt socket
5/16” Six point cross pin bolt wrench
Pry bars for removing the carrier case
Ball pein hammer
48 oz plastic dead blow hammer
Center Punch for marking carrier caps
Oil drain pan
Foot pounds torque wrench
0-50 Inch pound torque wrench with reverse adapters to attach to pinion nut.
A beam style torque wrench for torquing the LH ring gear bolts.
