Old 05-29-2021, 12:13 PM   #1
Asshat
Asshat's Avatar
Rear brakes sticking or dragging when moving slow
Not sure why, but every now and then, my brakes stick when going slow.
The rear end is out of an 83-ish truck, 3/4 ton, 8 lug.
If the brake adjuster is all the way in, it’s really free spinning. To get the shoes just touching the drums, the adjuster is half-way out.
And, I have these marks on the shoes like it’s skipping or bouncing.
The front has discs. I plan on eventually converting to disc on the rear.
1963 C20, small window, long bed
292, 4-speed
Asshat is offline   Reply With Quote
Old 05-29-2021, 01:05 PM   #2
KQQL IT
At the body shop.
KQQL IT's Avatar
Re: Rear brakes sticking or dragging when moving slow
Soft flex new ?
If it is not it could be collapsed internally
Old 05-29-2021, 01:24 PM   #3
Asshat
Asshat's Avatar
Originally Posted by KQQL IT View Post
Soft flex new ?
Soft flex?
292, 4-speed
Old 05-29-2021, 04:44 PM   #4
KQQL IT
At the body shop.
KQQL IT's Avatar
Flex hose between the frame and axle
Old 05-29-2021, 05:03 PM   #5
Asshat
Asshat's Avatar
It’s all new.
292, 4-speed
Old 05-29-2021, 11:14 PM   #6
KQQL IT
At the body shop.
KQQL IT's Avatar
Our 68 broke this blue spring and they over adjusted til they locked up.
Old 06-25-2021, 05:46 PM   #7
crazy longhorn
Fabricate till you "puke"
Just anouther thought....the rear diff is from a later truck? Maybe it has to do with piston size on the the brakes @ the rear(wheel cyls)? Longhorn
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 06-25-2021, 07:13 PM   #8
MySons68C20
MySons68C20's Avatar
Hey ASSHAT, any news? Imho aproper adj would probably cure your problem.
They appear to be a bit to tight.
MySons68C20 is offline   Reply With Quote
Old 06-25-2021, 08:00 PM   #9
Asshat
Asshat's Avatar
Well, the drums and shoes are new, and I have to extend the adjuster half way out before the shoes start getting close to the drums. If I don't get the adjustment extended out that far, I get no pedal.
I'm probably going to convert the rear end to discs, just haven't picked up the parts yet. I found a setup that will work, converting it to disc brakes; I could even use the ElDorado calipers and setup a parking brake.
292, 4-speed
