Who Me?
97 Tahoe Frontend knock out plugs
Hello all.
I took my truck to get it aligned and they said I needed to replace the upper ball joints. He also said, if I have the upper arms out to knock out the plugs. I had the arms out several years ago to replace the bushings, but didn't know about these plugs. He said it would make it easier to align, but its been aligned a few times with no complaints from other shops. In doing some research, I found this tool. OTC 7491C Upper Control Arm Knock-out Tool. I wanted to find out if this is necessary.
Steve1997 Tahoe LT 4D 2WD (DD) 2001 Blazer 4D 2WD 1961 Apache 10 (sold) 1965 C10 Stepper (sold) |
![]() ![]() Join Date: Jul 2002
Re: 97 Tahoe Frontend knock out plugs
I never did it on any of mine, but never had any tire wear or alignment tracking issues. I have hear of folks using it to get more adjustments, but never needed it on my 1/2 ton models. I unbderstand it does give the ability to fine tune the alignment alot more.
Who Me?
I have some tracking issues and slight tire wear. Its has been aligned in the past with no issues.
Watch out for your cornhole !
![]() Join Date: Jun 2003
No special tool needed for the knockouts really. I have done a lot of them and usually just use a prybar. Stick it in the slot and lever it sideways and it will snap them out. Once you remove the upper control arm you'll see what I'm talking about. The factory holes allow some adjustment but the knockouts allow full adjustment. The knockouts are already setup to be removed so it doesn't take much effort to snap them out of the holes.
https://www.youtube.com/watch?v=8uu6P8aA5nk
Who Me?
That makes it look easy!
Thanks Kevin
I have been down this road. Check out this thread including the last post that is mine.
http://67-72chevytrucks.com/vboard/s...d.php?t=799455 |
#7 | |
Who Me?
driving is in my blood
Mod the suspension and you'll see why they made room for more adjustment.
-78 c10 short/step: 388cid, M20, 5/5 drop, lots more. Playtoy and first vehicle. -98 c1500 x-cab: 5.7L, 17" rims, 5/6 drop, flowmaster, helper bags,NBS rear disk brakes. -02 Suburban 4x4: leveled front -CBR600F4i, CBR600RR, CBR1000RR, and standup skis DISCLAIMER: I cant spell for the life of me. |
My 97 4wd has 140K miles and is on the original front end components and has never been aligned! No weird tire wear and tracks straight. Just starting to get a bit of play in the steering though.
"You know that little thing in your head that keeps you from saying things you shouldn't? Yeah well, I don't have one of those" 1969 Mercury Cougar Standard 4 speed 1969 Mercury Cougar XR7 convertible 1970 4WD Chevrolet Suburban 1997 4WD Chevrolet Silverado Extended Cab Short Bed (purchased new January 1997) |
#10 | |
Mine didn't have them. At least not on the drivers side.
#11 | |
Who Me?
After looking at the situation, how can you make the cam adjustments if they are in there? When you rotate the cam, the bolt slides in that slot. Anyway, off to the alignment shop tomorrow. Thanks again for all the input!
#12 | |
I think they would be for assembly at the factory. That would be aligned or close when assembled.
Yeah, I am at ~175k on original steering/suspension parts on my '97. I've got a box (almost a crate) of mevotech parts waiting to go on.
Devin 1983 GMC High Sierra 2500, 4x4, RC/LB, 400 S.B., SM-465, NP-208, Corporate 10 bolt & 9.5" 14 bolt 1996 GMC Sierra SLE 3500 DRW, 4x4, EC/LB, Vortec 454, NV-4500, BW-4401, AAM 925 & AAM 1050 1997 GMC Sierra SLT 1500 4x4, Z71/F44, EC/SB, Vortec 350 My Introduction with my '83s History New Daily, the '96 |
Been doing alignments for 27 years. Any shop that says they aligned it with slugs still in only set toe. The very minimal amount of movement you get with them in is not enough to matter. The right way is to pull them. Besides, they drive better with camber closer to 0 anyway. Also, Drop toe down closer to 0.10 degrees.
Fast, Cheap, Reliable. You may pick two My 47/S10 build http://67-72chevytrucks.com/vboard/s...d.php?t=679723 |
| Bookmarks |
