Old 05-16-2021, 10:43 AM   #551
Kronald_70GMC
Kronald_70GMC's Avatar
Re: My 1970 GMC Project
Progress is going to be slow for a bit. Our little one was born on the 13th and she is perfect. This is Daphne.
Kyle
1970 GMC "Project Splice"
2017 Yukon Denali (Daily Driver)
IG: kyle_ronald
Kronald_70GMC is offline   Reply With Quote
Old 05-16-2021, 02:40 PM   #552
rowdy11
Congrats!
1970 K10 Shortbed LS L96 6L90
Follow the entire mess below!
Lola: My Moon Shot
rowdy11 is offline   Reply With Quote
Old 05-16-2021, 04:55 PM   #553
Chevys4life
Congrats!!!
Chevys4life is offline   Reply With Quote
Old 05-16-2021, 11:08 PM   #554
Scurry67
Right on! Enjoy this time with your little one, they change so fast!
67 SWB First Build
http://67-72chevytrucks.com/vboard/s...d.php?t=777171
Scurry67 is offline   Reply With Quote
Old 05-17-2021, 12:13 AM   #555
TA_C10
TA_C10's Avatar
Congrats!
TA_C10 Stage 1 build - http://67-72chevytrucks.com/vboard/s....php?p=8333444
"It's only money".
TA_C10 is offline   Reply With Quote
Old 05-17-2021, 01:31 AM   #556
Kronald_70GMC
Originally Posted by rowdy11 View Post
Congrats!
Originally Posted by Chevys4life View Post
Congrats!!!
Originally Posted by TA_C10 View Post
Congrats!
Thanks guys. We are just loving our time with her! She is so precious
Kyle
IG: kyle_ronald
Old 05-17-2021, 02:26 AM   #557
gmc684x4
Congrats cute little gal look forward to seeing wrenches in her hands on future builds
I work on my stuff with my kids great to teach them how to do real things with there hands
gmc684x4 is offline   Reply With Quote
Old 05-17-2021, 11:06 AM   #558
1971Stepside
Almost Satisfied
1971Stepside's Avatar
Wow! Congrats. She is beautiful
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021.
"I can't complain, but sometimes I still do. Life's been good to me so far."
1971Stepside is offline   Reply With Quote
Old 05-17-2021, 11:23 AM   #559
Kronald_70GMC
Thanks guys! She is so tiny. She was only 5LB 10OZ at birth.
Kyle
IG: kyle_ronald
Old 05-18-2021, 09:05 AM   #560
cornerstone
cornerstone's Avatar
Daphne is absolutely perfect.
Brian
1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 6 year frame off resto-mod.
cornerstone is offline   Reply With Quote
Old 05-18-2021, 09:20 AM   #561
Kronald_70GMC
Thanks. She absolutely is.
Kyle
IG: kyle_ronald
Old 05-23-2021, 09:42 PM   #562
Getter-Done
Getter-Done's Avatar
Congradulations.
84 Chevy K-20
Old 05-23-2021, 09:48 PM   #563
Kronald_70GMC
I made it into the shop for the first time since Daphne was born. I have filled in the radius in the rear corner of the passenger rocker/cab corner. I then started to fill the leading edge of the rocker as it was much to rounded for my liking. Only a small piece of wire was needed to match the door to the rocker near the front.
Kyle
IG: kyle_ronald
Old 05-23-2021, 09:49 PM   #564
Kronald_70GMC
Originally Posted by Getter-Done View Post
Congradulations.
Thank you!
Kyle
IG: kyle_ronald
Old 05-28-2021, 12:24 AM   #565
Scurry67
Gaps are looking real solid! Keep it up!
67 SWB First Build
Old 05-28-2021, 12:50 AM   #566
Kronald_70GMC
Thank you.
Kyle
IG: kyle_ronald
Old 05-30-2021, 09:14 PM   #567
Kronald_70GMC
Re: My 1970 GMC “Project Splice”
This afternoon I was planning to finish up welding the edge of the passenger rocker but that turned out to be a bust. I got all set up, turned on the welder and went to make a tack.....out of gas. Oh well, found something else to do for the afternoon. I cleaned up the upper windsheild area and got some marglass over the seams I welded shut. While I was there, I also filled in the spot welds under the lip of the roof edge. Once that was done, I tried yet another door I scored off of my uncle and bam! We have a winner. after a few more adjustments, I will be happy with this door as a start. The body lines are off very slightly but at least the upper window frame has nice gaps. I can always adjust the body lines with filler.
Kyle
IG: kyle_ronald
Old 05-30-2021, 10:27 PM   #568
siggyfreud
siggyfreud's Avatar
Congratulations on the newborn! Truck is looking awesome. I am jealous of the body/welding work. That's probably my weakest area unfortunately. I'll stay tuned and see if I pick up a few tips from you.
siggyfreud is offline   Reply With Quote
Old 05-30-2021, 10:31 PM   #569
Kronald_70GMC
Thanks man. It's been pretty cool being a dad so far. The biggest thing I can recommend is practice when it comes to welding. Stay tuned and you see alot of body work Thanks for the compliments on the truck as well.
Kyle
IG: kyle_ronald
Old 06-06-2021, 06:57 PM   #570
Kronald_70GMC
Progress continues on the passenger side. I got the rest of the rocker edge welded up and smoothed off. I also got a good coat of marglass laid down on the outside of the rocker. Should be done with welding on the cab now for a while so hopefully I'll be laying down some regular bondo soon.
Kyle
IG: kyle_ronald
Old 06-06-2021, 10:37 PM   #571
68 C10 Driver
First of all, congratulations on the arrival of little Daphne, she is so precious!
You really had a lot to deal with on this truck, and I thought the rust issues on my truck were bad... You are doing a spectacular job! I still have a rust area up under the dash where the cowl inlet rusted through. That will be a challenge to fabricate the replacement patches and get them welded in. Once that is done, I can epoxy prime the cab interior and apply the Lizard Skin.
Have you given any thought to applying any sound deadening/thermal barrier? My goal is to do such a good job rust proofing my truck that it can be a daily driver without the worry of it rusting out again.
Again congrats on the beautiful baby girl and the work you have done on your truck!
68 C10 Driver is offline   Reply With Quote
Old 06-06-2021, 11:10 PM   #572
Kronald_70GMC
Thank you for all the compliments. I am planning to use something like a raptor liner on the under side of the cab. On the inside, I'm planning to use something like a kilmat or equivalent. I'm hoping that will be sufficient to get fairly decent sound deadening. I also plan to use a piece of kilmat underneath the factory headliner.
Kyle
IG: kyle_ronald
Old 06-07-2021, 07:40 AM   #573
68 C10 Driver
You'll like the Raptor Liner, goes on easy and it is tough as nails.
Old 06-07-2021, 08:58 AM   #574
May70
May70's Avatar
Are you doing liner inside the cab? Im trying to figure out if I want to or not.
70 C20 Build link : Project Montezuma
http://67-72chevytrucks.com/vboard/s...d.php?t=794479
How to repair that rusted out 67-72 c10-c30! Please subscribe!
https://www.youtube.com/c/MaycoCustomRestorations
May70 is offline   Reply With Quote
Old 06-07-2021, 09:51 AM   #575
Kronald_70GMC
I'm not decided on that either. I was leaning more towards just doing the underside but not too sure. Does anyone think it would be beneficial to do both sides?
Kyle
IG: kyle_ronald
