Old 05-31-2021, 04:21 PM   #1
Breadstick
Ignition key cylinder trim ring
Is there a special tool or something to take the chrome ring that screws around the ignition key cylinder off? My 72 has three slots in it to use. I can use a screwdriver to get it mostly off but it gets tough at the end and won't unscrew anymore. I got matching keyed locks for the doors and ignition and need to change it.
Breadstick is offline   Reply With Quote
Old 05-31-2021, 04:47 PM   #2
Mac93
Mac93's Avatar
Re: Ignition key cylinder trim ring
There are removal tools you can purchase, such as this one from Brothers. My old man this several years ago to remove the bezel and works just fine.
Mac93 is offline   Reply With Quote
Old 05-31-2021, 05:25 PM   #3
BigBird05
You have to remove the ignition key cylinder before you can remove the trim ring. It will come loose and almost come off but the chrome trim ring on the key cylinder will not let the trim ring come off.
BigBird05 is offline   Reply With Quote
Old 05-31-2021, 06:38 PM   #4
Breadstick
Thanks. That's exactly what happened. How do you remove the cylinder once you get it loose?
Old 05-31-2021, 07:52 PM   #5
Steeveedee
Who Changed This?
Steeveedee's Avatar
See that little hole in the lock cylinder? Turn the key to "Accessory" and push a paper clip into that hole. When you pull the key out, the lock cylinder should come with it. If you live somewhere other than a dehydrated paradise like the California desert like I do, you may need a couple spritzes of lube.
~Steven
Simi Valley, CA
Old 05-31-2021, 08:22 PM   #6
Breadstick
Thanks a ton. I'll give it a shot tomorrow.
Old 05-31-2021, 10:46 PM   #7
LockDoc
The Older Generation
LockDoc's Avatar
Steeveedee has it pretty close. After you push the spring loaded pin in with the paper clip you have to turn the key a little more to the left. When it turns that extra little bit to the left you will have to remove the paper clip or it will bind up in the hole. You don't have to push hard on the spring loaded pin, and you shouldn't have to force anything to get it out. It will be easier to do if you screw the chrome bezel back on snug.
LockDoc
Leon
Old 06-01-2021, 05:33 AM   #8
BigBird05
In the south I had to spray lube in and cycle the key several times before the pin would push in and the cylinder would turn past the acc position.
Old 06-01-2021, 11:00 AM   #9
Steeveedee
Who Changed This?
Steeveedee's Avatar
LockDoc
I guess I got it that extra part of a turn with my untrained wiggling. I've probably replaced 5 ignition switches in my 45 years of working on vehicles.
~Steven
Simi Valley, CA
