Old 06-04-2021, 08:08 PM   #8
ron350
ron350's Avatar
Re: Parking brake cable
Ok once you have the 3 cable guides hooked in to the frame hook the cable (part # 2) through them.
Then you place part #6 over the cable and slide it on to the threaded rod and put the nut on the threaded rod.
Then you tighten the nut down until you can only push the parking brake pedal down 3 clicks
You will need a ½ wrench, vice grips and probably extra hands.
Stock 75 C10 step side.
350 2 BBL, 350 trans. 150K miles.
ron350 is offline   Reply With Quote
