72 C-20 Help
Morning Guys Ive got a 72 C-20 350 motor id like to run a fan cluch so it will run a little cooler this summer the parts guy at O,rielly,s looked up my truck he said the truck came with a thermal fan cluch from the factory?? is that what i need ? Thanks Saddletramp
Re: 72 C-20 Help
I used a Hayden 2747 when I replaced the original non working unit. He’s just calling it by the technical term . Fan clutch is a thermal clutch
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. |
Who Changed This?
![]() Join Date: Jan 2013
Re: 72 C-20 Help
There are some fan clutches that do not have the thermal feature.
A non-thermal fan clutch is nothing more than a thermal fan clutch always partly engaged. It provides adequate cooling when needed, however, it does not save you money by disengaging (operating at a lower RPM) when additional cooling is not needed. You want a thermal fan clutch.
20' Daredevil (Ret)
![]() Join Date: May 2003
Re: 72 C-20 Help
^^ What they said. Hayden 2747 is a heavy duty thermal fan clutch made by Four Seasons in Lewisville, Texas. It is a perfect replacement for trucks with factory A/C.
A heavy duty clutch will cool better than a standard duty, and severe duty is overkill for normal use, even in hot climates. You should be running an 18" six-blade or better yet a seven-blade fan. Differences between standard duty, heavy duty, and severe duty clutches can be seen here: https://www.haydenauto.com/en/produc...-types/thermal
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
Re: 72 C-20 Help
Thanks for the answer appreciate ya where can i get the 18inch blade fan the one i have doesn't have the hole in the middle for the cluch fan ? Thanks again Saddletramp
20' Daredevil (Ret)
Re: 72 C-20 Help
Summit Racing has a 6-blade https://www.summitracing.com/parts/der-17118
Personally I prefer a 7-blade like my OEM fan. Ah, here we go: https://www.summitracing.com/parts/gmk-4012312681 Or try a junkyard, might get lucky and save some $$ to boot.
