WTB dually axles and 10 bolt 4.10 gears (or close) for front and rear for step truck
i need a 3.73-4.10 gears for front and rear of a 87 step truck both axles are 10 bolt
and i need a dually setup that will fit a 85 GMC let me know what you guys have.
67 c-10, 400 SB, TH350, 4.10 gears, Blazer tank,camaro tach, sidemarker fuel fill (soon) WTB: stepside parts, 67 front end parts, 67 small window cab. posi for 3.73 or 4.10 for 12 bolt and 10 bolt. |
Dually rear
I got a complete dually rear. It is a Dana 70 out of a 87 chevy dually.
$400 complete with u-bolt plates and sway bar. Located in Salisbury NC BBB ![]() |
no way to get that to PA.
Dually Rear
I also have a dually Dana 70, 4:10 ratio, open, from a mid eighties 1 ton plus van with a box on the rear. The dimensions, backing plate to backing plate, leaf spring perch to perch and overall are available. I thought I had them with me, but they are not in this notebook. Remember, this is a van dually and not a pickup dually. There are differences, which I don't know all of them. This axle has the leaf springs still attached. Asking $350. Did you ever decide on cabs for your early project?
Drop me an email if you want to inspect the rear. |
Dimensions
Found the dimensions. May need to reconfirm for you. Backing plate to Backing plate - 54 3/4", Center leaf to Center leaf perch - 50", Outside wheel bead to outside wheel bead, of duals - 92". Hope this helps.
havent really decided on a cab why? also im not sure how much he wants to spend on it.the 85 is my buddies dads the 87 is my buddies the 67 is mine and the 86 is my dads. the 85 we wanna make dually the 87 we need new gears or axles and my 67 has 4.11s so i wanna get an overdrive trans.
