![]() Join Date: Dec 2009
Re: Someone save this truck
Thanks 57taskforce
![]() You have a Great Heart. ![]() That truck will live another Day ![]() .
________________________________________________________________________________________ ____________________________________________ The early bird gets the worm, But the second mouse gets the cheese 84 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build |
#2 | |
All about them K’s
![]() Join Date: Jun 2014
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne: 5” lift, 35’s, front dana 60 blah blah blah… http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB: 4” lift 33”s… in a million pieces http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 35x12.5x20’s |
Great buy . This would be a perfect truck for an LS swap.
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. |
Nice truck. Half the "swap" is already done! -klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold |
![]() Join Date: May 2013
Now that my white GMC is running cool, I can keep her as is.
Big Blue will definitely get an LS conversion. It will be a first for me, so I am open to suggestions. ![]()
1971 GMC C15 Sierra Grande SWB 1972 Chevy C10 Custom Deluxe LWB 2018 GMC Yukon Denali |
Congrats on the "new" truck. Good decision on the LS swap. I am nearing the later stages of my swap into my '71 lwb. Hop on over to the 'LSx Swap" forum and read up.
Since you have a factory air truck, I highly recommend you keep the LS low mount a/c compressor. Use the Hooker Blackheart mounts and cross member and your compressor will clear the frame easily and the engine/trans will retain proper driveline angles. Plus, no modification to the mounts or a/c bracket. I also am changing to a more modern accumulator/orifice tube a/c system to work better with cycling a/c compressor. I am controlling the compressor through the ECM. I also highly suggest you buy an entire running vehicle as a donor for the swap. It is amazing how many parts you can scavenge from the donor. My build will cost just under $4k with me doing all the work. Large $ chunks are for specialty items like a $315 analog speedometer drive...I'm keeping my '71 gauges. |
1970 Daily Driver
Nice buy on the blue beast. Great to see the forum helping each other out.
David, my boy is putting an LS in his 68 and having problems with the ac compressor clearing. The motor already had conversion mounts on it when we got it that have two possible positions. I would love to be able to leave the compressor down low. Can you post a link of the mounts that make this possible?
It's not truly yours if you didn't build it yourself or if you don't do your own maintenance. |
Florida Edition
![]() ![]() Join Date: Oct 2010
Very well done! Congrats to all involved.
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod 67 C-20 Slant Back Wrecker "Mad Max" 67 C-10 Ratrod "Step-N-Wolf" 71 Serro Scotty Sportsman camper "Scotty" 97 LT1 Z28 "The Hornet" Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684 Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394 |
#9 | |
https://www.holley.com/brands/hooker...ap_components/ Not sure if a '68 has the wide or narrow frame rails...but Hooker makes the mounts for either. My experience was that no clearance issues with compressor. But, since the Blachheart mounts the engine low, the PS pump required a bit of trimming on my narrow frame rails. |
#10 | |
#11 | |
The Older Generation
http://67-72chevytrucks.com/vboard/f...prune=-1&f=206 Like DavidF said, read, read, read, and follow some of the links, and read, read, read some more.... ![]() LockDoc
