![]() Join Date: Feb 2019
1970 Bronco
Spent part of last summer trying to hunt down a classic mustang to restore for my wife, but ended up bringing this home instead. It is in pretty rough shape but they do reproduce pretty much every part for these now. I plan to drive it around some before starting on the restoration in the fall. Hope to have my dad's mustang complete by then as well so I can bring my GMC home and have both of my projects under the same roof.
1964 GMC Fleetside SWB 1966 Mustang Coupe 2013 Tahoe LT Last edited by 1slo64; 02-14-2021 at 04:49 AM. |
Re: 1970 Bronco
First thing I did was toss out the crappy bench seat a PO put in place of the original bucket seats. Bought a set of Roush RS leather/alcantara seats for it and with a little modification they fit.
1964 GMC Fleetside SWB 1966 Mustang Coupe 2013 Tahoe LT |
Re: 1970 Bronco
My plan is to go with a mostly stock exterior, so the wheels and tires had to go. I hunted down a set of original refinished wheels and bought 30x9.5x15s to go on them. I also have a set of original hubcaps that need a little work but were really cheap.
![]() Join Date: May 2015
Re: 1970 Bronco
should be a fun one....looks like a lot of metal work ahead for you...
![]() ![]() Join Date: Nov 2008
Re: 1970 Bronco
This will be a nice project once you evict the tin worms. She has a LOT of them but they can be cured with a 55 gallon drum of elbow grease! Can't wait to see the work
'55 Big Window Shortbed, Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's Dan's '55 Big Window "Build" - Well, Kinda! |
Re: 1970 Bronco
Thankfully most of the rusted stuff is all just spot welded in place so replacement should be fairly easy.
Re: 1970 Bronco
Fun and nice rigs. Should be really sweet when done.
My dad had a '69 when I was about 14-15. 289 with 3OT. My buddies and I took it on many a fishing trip in the Ozark mountains.
1967 C10 1997 Ford Ranger 2020 Toyota 4Runner 2024 Toyota Tundra |
Re: 1970 Bronco
Those things have been really going up in value in the past couple years! Lorne
Proprietor of Dale's Corner
![]() Join Date: Nov 2012
Re: 1970 Bronco
In to watch!
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man R.I.P. FleetsidePaul |
Re: 1970 Bronco
They definitely have, I feel like I got a good deal at $4500.
Re: 1970 Bronco
Got the wheels and tires mounted yesterday. Now just need a fresh battery and see if it starts.
Re: 1970 Bronco
Ordered new quarter panels and front fenders today, ready to see if start looking like a normal bronco again. Also forgot I rebuilt the carburetor last month until I was looking at pictures. I just need a new battery and hopefully I will hear the 302 fire up.
Re: 1970 Bronco
New sheet metal showed up today.
Re: 1970 Bronco
I hope it fits as nice as it looks..
#15 |
Re: 1970 Bronco
Yeah......what Dale said...
#16 |
Re: 1970 Bronco
The fronts fit fairly well, but like any aftermarket part there is some work to be done. The main area that needs work seems to be where the fender mounts near the door, it doesn't line up with the bolt holes or the door post.
I did have to cut every bolt off, they were so rusty they might as well be fused together. Also got a better look at the rust, little worse than I expected but I knew it was there. Guess that is what happens when you leave it neglected in the woods of central Alabama for years. ![]() ![]() ![]() ![]()
#17 |
Its a Truck Thing......
Re: 1970 Bronco
I picked up a 73 and it had lots of fun made into from previous owners. Just got my 302 back from the machine shop so It will have a completed rebuilt drivetrain except for the front axle. Good thing about Broncos are that you can get all the steel to rebuild the entire vehicle fairly cheap.
Smitty
71 C10 283/3SPD Full Resto 70 C10 Suburban Former military GSA truck. 72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378 72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110 68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head 71 C30 Wrecker 71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck 68 GMC Long Stepside. They keep following me https://67-72chevytrucks.com/vboard/...d.php?t=841215 69 C30 Former Motor Home, Flat Bed time 70 G20 Red-E-Kamp Conversion "I'm your Boogy Van" |
#18 |
![]() Join Date: Mar 2013
Re: 1970 Bronco
Nice project you’ve got there.
I’ve been working on mine off and on the last couple years. I just had to do minimal rust repair in the usual spots. Yes, the replacement sheet metal is available but it still takes a lot of patience to work on these Broncos because of all of the spot welds holding them together. Looking forward to seeing your progress! |
#19 |
Re: 1970 Bronco
Hadn't planned on going EFI but when a complete intake and wiring harness came up for $50 I couldn't say no. So starting this week I'm going to start working on the wiring harness and removing everything I don't need.
#20 |
![]() Join Date: Jun 2007
Re: 1970 Bronco
Sweet, following!
Click on my Not really a build thread, yet NOT SO RUST FREE RUST FREE BLAZER LS ENGINE SWAP INFORMATION THREAD BOLT RESTORATIONS 4l60 to an NP205 |
#21 |
Re: 1970 Bronco
Rolled it outside to reorganize the garage a couple weeks ago. I also purchased mostly complete long block out of a 97 explorer. That gives me the better flowing GT40P heads and roller block to go along with the efi I will be using. Also started working on making the efi a stand alone system, lots of cutting and rewiring ahead of me.
#22 |
Re: 1970 Bronco
Awesome project.
#23 |
Re: 1970 Bronco
ugghhhh...thats a lot of wires..!!!!
#24 |
Re: 1970 Bronco
And that's just one portion of the harness. Thankfully I have a couple youtube videos to watch that go step by step.
#25 |
Re: 1970 Bronco
I hope the youtube guy knows what he's doing. That looks like a lot of heartburn and headaches.....
| Bookmarks |
