Moderator
![]() Join Date: Oct 2008
Re: 1973-1991 Dual fuel tank systems theory of operation
84 wouldn't have Fuel Injection GM started that on the 1987 trucks.
The mechanical fuel pump will deliver fuel at the proper pressure for your carburetor from whichever tank you select. Change the switch, check for volts and ground at the plug, and then check the old valve operation before you do anything with the new valve. A fair percentage of the time the old valve will work fine. From 1981 on GM stopped using the AUX and Main designations and got right to the point LH & RH. You should make sure the LH tank is selected when the switch is set to LH and RH when RH is selected.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
| Bookmarks |
